[mapguide-users] MapAgent.exe persists after browser close
Kenneth, GEOGRAF A/S ks at geograf.dk
Tue Jul 17 03:12:59 EDT 2007
I belive that MapAgent.exe is supposed to keep running.
IIS/Apache will load/unload fastCGI, to avoid continously reloading
MapAgent.exe.
If you are using WinXP IIS, you are likely refering to the IIS
connection limit on WinXP.
You can increase the number of allowed connections to 40.
Instructions can be found here:
http://weblogs.asp.net/cazzu/archive/2003/10/10/31476.aspx
Regards, Kenneth, GEOGRAF A/S
nicholda skrev:
> Hi All,
>   I am having trouble with MapAgent.exe, after closing the web browser
> MapAgent.exe is still running in the background.  Eventually I hit the max
> number of connections and can't make another connection until I manually end
> the MapAgent processes running in the background.  I am running MGOS 1.2.
> Could someone point me in the right direction for resolving this issue.
> Thanks,
> David
