[mapguide-users] Map Agent won't load from Web Studio
Kenneth, GEOGRAF A/S
ks at geograf.dk
Thu Jul 19 04:26:19 EDT 2007
What do you mean by "Map Agent"?
There is a process that handles MapGuide requests, that is called
"MapAgent.exe", but you should not encounter that one from WebStudio.
Previews do not work inside WebStudio, if you don't have the PHP API.
Regards, Kenneth, GEOGRAF A/S
jamesdudden skrev:
> Hi kenneth
> Am using:
> Windows XP and IIS 5.0 developing with ASP (have latest version installed)
> Using MG Opensource 1.1 and Web Studio.
> The site Admin and tests work fine.
> The URL for Web Studio is http://localhost/mapguide
> Web Studio opens and the samples load, the site admin opens but the Map
> Agent returns the HTTP error - 403
> Kind Regards
> James Dudden
> Kenneth, GEOGRAF A/S wrote:
>> What server operating system are you using?
>> What webserver? What API did you choose.
>> Did you install 1.2 RC2, 1.1, Enterprise or another version?
>> Does the Site Administrator work?
>> What URL do you type in the MapGuide Studio "Connect" dialog?
>> jamesdudden skrev:
>>> Hi all
>>> I have been through the MG install guide and loaded the samples
>>> successfully. The Map Agent test brings up an XML document, Which means
>>> it's
>>> working, i think?
>>> When i open Web Studio and try to open the Map Agent i get an error
>>> message:
>>> YOU ARE NOT AOUTHORISED TO VIEW THIS PAGE.
>>> HTTP Error 403 - Forbidden
>>> Any ideas anyone?
>>> Kind Regards
>>> James Dudden
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20070719/51ee6c36/attachment.html
