[mapguide-users] Map Agent won't load from Web Studio
jamesdudden jamesdudden at blueyonder.co.uk
Thu Jul 19 13:33:34 EDT 2007
Thankyou for taking time to reply Kenneth. I have now downloaded a trial copy
of MapGuide Studio. Hopefully I will have better luck.
Regards
James Dudden
Kenneth, GEOGRAF A/S wrote:
> What do you mean by "Map Agent"?
> There is a process that handles MapGuide requests, that is called
> "MapAgent.exe", but you should not encounter that one from WebStudio.
> Previews do not work inside WebStudio, if you don't have the PHP API.
> Regards, Kenneth, GEOGRAF A/S
> jamesdudden skrev:
>> Hi kenneth
>> Am using:
>> Windows XP and IIS 5.0 developing with ASP (have latest version
>> installed)
>> Using MG Opensource 1.1 and Web Studio.
>> The site Admin and tests work fine.
>> The URL for Web Studio is http://localhost/mapguide
>> Web Studio opens and the samples load, the site admin opens but the Map
>> Agent returns the HTTP error - 403
>> Kind Regards
>> James Dudden
>>> What server operating system are you using?
>>> What webserver? What API did you choose.
>>> Did you install 1.2 RC2, 1.1, Enterprise or another version?
>>> Does the Site Administrator work?
>>> What URL do you type in the MapGuide Studio "Connect" dialog?
>>> jamesdudden skrev:
>>>> Hi all
>>>> I have been through the MG install guide and loaded the samples
>>>> successfully. The Map Agent test brings up an XML document, Which means
>>>> it's
>>>> working, i think?
>>>> When i open Web Studio and try to open the Map Agent i get an error
>>>> message:
>>>> YOU ARE NOT AOUTHORISED TO VIEW THIS PAGE.
>>>> HTTP Error  403 - Forbidden
>>>> Any ideas anyone?
>>>> Kind Regards
>>>> James Dudden
>>> mapguide-users mailing list
>>> mapguide-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
View this message in context: http://www.nabble.com/Map-Agent-won%27t-load-from-Web-Studio-tf4104314s16610.html#a11694103
