[mapguide-users] Help please with error: 'requested provider: Autodesk Raster'
Kenneth, GEOGRAF A/S ks at geograf.dk
Tue Jul 24 05:32:32 EDT 2007
You must manually install the raster providers.
Unfortunately the binaries for FDO GDAL 3.2.0 are no longer avalible.
You can download the source, and compile it yourself.
If you are not used to building code, it might be an overwhelming task.
If no-one is willing to send you a copy, you can switch to MGOS 1.2, as
the GDal provider is included with that release.
Regards, Kenneth, GEOGRAF A/S
jamesdudden skrev:
> Hi all
> I am running MGOS 1.1, XP, IIS5.1, ASP and MGStudio. I have been working
> through the getting started pdf that comes with studio and everything works
> except when loading tiff files. It comes up with the error 'server does not
> support requested provider: Autodesk Raster'.
> I have searched around the forum and found some other poeople who
> experienced the same problem. The answer seems to lie in downloading a
> 'raster.zip' file, but i can't find it as some of the links are dead.
> Is this the right file to download? Where can i download it from? How do i
> install it once it is downloaded?
> Any help is appreciated greatly.
> Regards
> James Dudden
