[mapguide-users] Help please with error: 'requested provider:
Autodesk Raster'
jamesdudden
jamesdudden at blueyonder.co.uk
Tue Jul 24 06:21:35 EDT 2007
Kenneth
Thankyou for the reply.
I am not used to building code so this will be a last resort.
If anybody could send me a copy I would be hugely gratefull.
If not do you know the implications of upgrading to MG 1.2? Is it likely to
cause conflicts or problems etc?
Thanks again
Regards
James Dudden
Kenneth, GEOGRAF A/S wrote:
> You must manually install the raster providers.
> Unfortunately the binaries for FDO GDAL 3.2.0 are no longer avalible.
> You can download the source, and compile it yourself.
> If you are not used to building code, it might be an overwhelming task.
> If no-one is willing to send you a copy, you can switch to MGOS 1.2, as
> the GDal provider is included with that release.
> Regards, Kenneth, GEOGRAF A/S
> jamesdudden skrev:
>> Hi all
>> I am running MGOS 1.1, XP, IIS5.1, ASP and MGStudio. I have been working
>> through the getting started pdf that comes with studio and everything
>> works
>> except when loading tiff files. It comes up with the error 'server does
>> not
>> support requested provider: Autodesk Raster'.
>> I have searched around the forum and found some other poeople who
>> experienced the same problem. The answer seems to lie in downloading a
>> 'raster.zip' file, but i can't find it as some of the links are dead.
>> Is this the right file to download? Where can i download it from? How do
>> i
>> install it once it is downloaded?
>> Any help is appreciated greatly.
>> Regards
>> James Dudden
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
View this message in context: http://www.nabble.com/Help-please-with-error%3A-%27requested-provider%3A-Autodesk-Raster%27-tf4134584s16610.html#a11760210
