[mapguide-users] RE: OGR and MGOS
Traian Stanev traian.stanev at autodesk.com
Thu Jul 26 11:27:08 EDT 2007
Ah, oops, I misread, you are not using the OGR provider when you see your selection problem. Just ignore what I said then.
	-----Original Message-----
	From: mapguide-users-bounces at lists.osgeo.org on behalf of Traian Stanev
	Sent: Thu 7/26/2007 11:23 AM
	To: MapGuide Users Mail List; mapguide-users at lists.osgeo.org
	Cc:
	Subject: RE: [mapguide-users] RE: OGR and MGOS
	The selection problem you are describing is fixed in the latest available build of the OGR provider.
	Traian
		From: mapguide-users-bounces at lists.osgeo.org on behalf of Dhirendra Kumar
		Sent: Thu 7/26/2007 3:24 AM
		To: mapguide-users at lists.osgeo.org
		Cc:
		Subject: Re: [mapguide-users] RE: OGR and MGOS
		Hi Rahul-2,
		Are you sure that OGR 3.2 and MGOS 1.2.0 will work fine and provide
		connectivity with MySQL ? But MGOS 1.2.0 come with FDO 3.2.2.0 and OGR
		provider also available in version OGR 3.2.2, So for MySQL connectivity i'll
		have to reinstall FDO 3.2 with MGOS .1.2.0 ?. If you have any suggestion
		then please replay me. I can establish connection MGOS 1.1.0 with MySQL but
		problem in Layer polygon selection, when i select one polygon then another
		near polygon get highlighted and for this resion my project get stuck. So i
		am searching another FDO provider like postGIS or any good database that
		solve my problem. If you have any idea or suggestion then help me. Thankyou
		in Advance.
		Regards,
		Dhirendra kumar
		Rahul-2 wrote:
		> Hi ,
		>             I think you check your connection string ,it should be--
		>   POSTGIS
		>   DataSource -----PG: host=xxxx port=xxxx dbname=xxxx user= xxx
		> password=xxx
		>   ReadOnly--------FALSE
		>   same kind of setting you can try for the MySQL.
		>   DataSource -----PG:dbname=xxxx,user=
		> xxx,password=xxx,host=xxxx,port=xxxx
		>   I think OGR 3.2 doesn't work properly with MGOS 1.1 so try MGOS 1.2.0
		> with FDO 3.2.0.
		>   Cheers
		>   Max !!
		> nicholda <nicholda at talgov.com> wrote:
		> I have not tried this with MySql. The problems that was experiencing were
		> with PostGis. I resolved it by trying the different OGR's available. I
		> have
		> attached the one that I am currently using for PostGis. I hope this helps.
		> Below is also the modifications that need to be made to the Providers.xml.
		> David
		> OSGeo.OGRProvider.3.2
		> FDO Provider for OGR
		> Access to OGR data sources
		> False
		> 3.2.0.0
		> 3.2.0.0
		> C:\Program
		> Files\MapGuideOpenSource\Server\Bin\FDO\OGRProvider.dll
		> Dhirendra Kumar wrote:
		>> Hi Nicholda,
		>> I am also using MGOS 1.1 and Mapguide Studio 07, and OGR 3.2 and i can
		>> see
		>> Datasource and Readonly property, but i can't establish connection with
		>> MySQL Database. you have any idea about this then help me pls. i enter in
		>> connection string in datasource is
		>> MYSQL:westholland,user=root,password=psv9570,port=3306, but it is not
		>> working. help me.
		>> Regards,
		>> Dhirendra Kumar
		>> nicholda wrote:
		>>> I am also using MGOS 1.1 and Mapguide Studio 07 6.5. I get a successful
		>>> connection, but when I try to create a new layer from Postgres. I get
		>>> the attached error message.
		>>> Traian Stanev wrote:
		>>>> I've seen that happen with some builds of the provider -- Studio does
		>>>> not display the connection properties. What version of MapGuide are you
		>>>> using?
		>>>> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Rahul
		>>>> Sent: Wednesday, May 16, 2007 3:05 AM
		>>>> Subject: RE: [mapguide-users] OGR and MGOS
		>>>> _______________________________________________
		>>>> mapguide-users mailing list
		>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
		>>> http://www.nabble.com/file/p10663767/Error.JPG
		> http://www.nabble.com/file/p11781363/OGRProvider.dll OGRProvider.dll
		> http://www.nabble.com/OGR-and-MGOS-tf3728865s16610.html#a11781363
		> Sent from the MapGuide Users mailing list archive at Nabble.com.
		> Be a better Heartthrob. Get better relationship answers from someone who
		> knows.
		> Yahoo! Answers - Check it out.
		View this message in context: http://www.nabble.com/OGR-and-MGOS-tf3728865s16610.html#a11805486
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20070726/13646862/attachment.html
