[mapguide-users] RE: OGR and MGOS
Kenneth, GEOGRAF A/S
ks at geograf.dk
Thu Jul 26 12:07:29 EDT 2007
I belive the problem is the same as it was in the OGR provider.
It would probably be possible to fix in almost the same way,
but using FDO intersection test instead of OGR intersection tests.
It would be possible to use the OGR provider for MySQL data, but the
official release is built without MySQL.
I cannot figure out how to build it "linked in" or "delayed-loaded",
thus requiring the mysql.dll to be distributed alongside.
Regards, Kenneth, GEOGRAF A/S
Traian Stanev skrev:
> Ah, oops, I misread, you are not using the OGR provider when you see
> your selection problem. Just ignore what I said then.
> -----Original Message-----
> *From:* mapguide-users-bounces at lists.osgeo.org on behalf of Traian
> Stanev
> *Sent:* Thu 7/26/2007 11:23 AM
> *To:* MapGuide Users Mail List; mapguide-users at lists.osgeo.org
> *Cc:*
> *Subject:* RE: [mapguide-users] RE: OGR and MGOS
> The selection problem you are describing is fixed in the latest
> available build of the OGR provider.
> Traian
> of Dhirendra Kumar
> *Sent:* Thu 7/26/2007 3:24 AM
> *To:* mapguide-users at lists.osgeo.org
> *Cc:*
> *Subject:* Re: [mapguide-users] RE: OGR and MGOS
> Hi Rahul-2,
> Are you sure that OGR 3.2 and MGOS 1.2.0 will work fine and
> provide
> connectivity with MySQL ? But MGOS 1.2.0 come with FDO 3.2.2.0
> and OGR
> provider also available in version OGR 3.2.2, So for MySQL
> connectivity i'll
> have to reinstall FDO 3.2 with MGOS .1.2.0 ?. If you have any
> suggestion
> then please replay me. I can establish connection MGOS 1.1.0
> with MySQL but
> problem in Layer polygon selection, when i select one polygon
> then another
> near polygon get highlighted and for this resion my project
> get stuck. So i
> am searching another FDO provider like postGIS or any good
> database that
> solve my problem. If you have any idea or suggestion then help
> me. Thankyou
> in Advance.
> Regards,
> Dhirendra kumar
> Rahul-2 wrote:
> > Hi ,
> > I think you check your connection string ,it
> should be--
> > POSTGIS
> > DataSource -----PG: host=xxxx port=xxxx dbname=xxxx user= xxx
> > password=xxx
> > ReadOnly--------FALSE
> > same kind of setting you can try for the MySQL.
> > DataSource -----PG:dbname=xxxx,user=
> > xxx,password=xxx,host=xxxx,port=xxxx
> > I think OGR 3.2 doesn't work properly with MGOS 1.1 so try
> MGOS 1.2.0
> > with FDO 3.2.0.
> > Cheers
> > Max !!
> > nicholda <nicholda at talgov.com> wrote:
> > I have not tried this with MySql. The problems that was
> experiencing were
> > with PostGis. I resolved it by trying the different OGR's
> available. I
> > have
> > attached the one that I am currently using for PostGis. I
> hope this helps.
> > Below is also the modifications that need to be made to the
> Providers.xml.
> > David
> > OSGeo.OGRProvider.3.2
> > FDO Provider for OGR
> > Access to OGR data sources
> > False
> > 3.2.0.0
> > 3.2.0.0
> > C:\Program
> > Files\MapGuideOpenSource\Server\Bin\FDO\OGRProvider.dll
> > Dhirendra Kumar wrote:
> >> Hi Nicholda,
> >> I am also using MGOS 1.1 and Mapguide Studio 07, and OGR
> 3.2 and i can
> >> see
> >> Datasource and Readonly property, but i can't establish
> connection with
> >> MySQL Database. you have any idea about this then help me
> pls. i enter in
> >> connection string in datasource is
> >> MYSQL:westholland,user=root,password=psv9570,port=3306, but
> it is not
> >> working. help me.
> >> Regards,
> >> Dhirendra Kumar
> >> nicholda wrote:
> >>> I am also using MGOS 1.1 and Mapguide Studio 07 6.5. I get
> a successful
> >>> connection, but when I try to create a new layer from
> Postgres. I get
> >>> the attached error message.
> >>> Traian Stanev wrote:
> >>>> I've seen that happen with some builds of the provider --
> Studio does
> >>>> not display the connection properties. What version of
> MapGuide are you
> >>>> using?
> >>>> From: mapguide-users-bounces at lists.osgeo.org
> >>>> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf
> Of Rahul
> >>>> Sent: Wednesday, May 16, 2007 3:05 AM
> >>>> To: MapGuide Users Mail List
> >>>> Subject: RE: [mapguide-users] OGR and MGOS
> >>>> _______________________________________________
> >>>> mapguide-users mailing list
> >>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
> >>> http://www.nabble.com/file/p10663767/Error.JPG
> > http://www.nabble.com/file/p11781363/OGRProvider.dll
> OGRProvider.dll
> > View this message in context:
> http://www.nabble.com/OGR-and-MGOS-tf3728865s16610.html#a11781363
> > Sent from the MapGuide Users mailing list archive at Nabble.com.
> > Be a better Heartthrob. Get better relationship answers from
> someone who
> > knows.
> > Yahoo! Answers - Check it out.
> http://www.nabble.com/OGR-and-MGOS-tf3728865s16610.html#a11805486
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20070726/3479b842/attachment.html
