[mapguide-users] Raster did not load/show
didit.s banuardi.n
didithoe at gmail.com
Mon Jul 30 02:24:57 EDT 2007
ups...
sorry ...how stupid i'am :-)
it' works...
the dark blue image is an ocean.... seems i forgot to set up the "initial
map view"
conclusion:
there's a problem with my "tif" image file
thak you for the advice to try ecw file...
On 7/30/07, didit.s banuardi.n <didithoe at gmail.com> wrote:
> oke, next i'm testing it with ECW file,
> to make it available for other to test the case.., i ' m using the "blue
> marble" "ecw" file , available at demis.
> http://support.demis.nl/files/3/demiswms/entry1337.aspx
> the steps:
> 1.)download the ecw files (2,east and west) to
> "c:\vhdBRDspatial\Bluemarble" directory
> 2.)download the ECW plugin from "http://home.gdal.org/dl/mapguide/"
> (gdal_ecw_120.zip)
> 3.) copy the "gdalplugins" folder to "BIN" directory.
> 4.)restart the service
> 5.) RUN debug mode
> 5.)open the MG studio 2007 and build the datasource (Default
> rasterfilelocation: c:\vhdBRDspatial\Bluemarble\)....layer...,map..., web
> layout...
> and still the image didn't show, only a dark blue image....
> this is the debug result....
> (note the red font...is it correct?)
> <http://localhost:8008/mapguide/configbuilder.php>
> C:\Program Files\MapGuideOpenSource\Server\Bin>set CPL_DEBUG=ON
> C:\Program Files\MapGuideOpenSource\Server\Bin>mgserver STOP
> Stopping the server service.
> C:\Program Files\MapGuideOpenSource\Server\Bin>mgserver RUN
> Running the server interactively as an application instead of as a
> service.
> (460|2360) Server starting...
> (460|2360) PROJ4 Coordinate System Library
> (460|2360) Server started.
> GDAL: Auto register C:\Program
> Files\MapGuideOpenSource\Server\Bin\gdalplugins\g
> dal_ECW.dll using GDALRegister_ECW.
> ECW: Actually creating ECW driver.
> ECW: OpenECW(C:\vhBRDspatial\BlueMarble\/land_shallow_topo_east.ecw)
> ECW: Open(C:\vhBRDspatial\BlueMarble\/land_shallow_topo_east.ecw)
> ECW:
> NCScbmOpenFileView(C:\vhBRDspatial\BlueMarble\/land_shallow_topo_east.ecw):
> eErr = 0
> ECW: FileInfo: SizeXY=21600,21600 Bands=3
> OriginXY=0,90 CellIncrementXY=0.00833333,-0.00833333
> ECW: projection=RAW, datum=RAW
> GDAL: GDALOpen(C:\vhBRDspatial\BlueMarble\/land_shallow_topo_east.ecw)
> succeeds
> as ECW.
> ECW: OpenECW(C:\vhBRDspatial\BlueMarble\/land_shallow_topo_west.ecw)
> ECW: Open(C:\vhBRDspatial\BlueMarble\/land_shallow_topo_west.ecw)
> ECW:
> NCScbmOpenFileView(C:\vhBRDspatial\BlueMarble\/land_shallow_topo_west.ecw):
> eErr = 0
> OriginXY=-180,90 CellIncrementXY=0.00833333,-0.00833333
> GDAL: GDALOpen(C:\vhBRDspatial\BlueMarble\/land_shallow_topo_west.ecw)
> succeeds
> as ECW.
> ECWRasterBand: RasterIO(nXOff=0,nYOff=10736,nXSize=60,nYSize=128 ->
> 533x566)
> 533x566)
> 533x566)
> ECWRasterBand: RasterIO(nXOff=21540,nYOff=10736,nXSize=60,nYSize=128 ->
> 533x566)
> 533x566)
> 533x566)
> br,
> didit
> On 7/26/07, ori gudes < ori at sinapistech.com> wrote:
> > Hi
> > Can you Verify if other formats work ? such as ECW or Mr' SID ? that
> > can
> > help you to know if it is a general problem or only at this format/file.
> > Regards Ori
> > didit.s banuardi.n wrote:
> > > i'm inserting another layer on top and bottom of the layer raster,
> > still
> > > the raster layer didn''t show up...
> > > but the "initial map view" shows the correct coordinate of raster
> > layer.
> > > fyi,
> > > -i'm using MGOS 1.2.0 RC2, MGS 2007,AJAX dotnet viwer, Win 2003 Sp2 On
> > > Virtual Server environment
> > > -the raster layer size is 250 Mb, is it to big or not?
> > > any suggest to debug the problem??
> > > On 7/23/07, ori gudes <origu at omnitech.co.il> wrote:
> > >> Hi
> > >> Did you try to insert another layer (in t the Map) from the same
> > >> geographical area on top of the raster ?
> > >> Maybe it is just matter of coordinate's problems ?
> > >> Regards Ori
> > >> > hi,all
> > >> > i'm testing the MGOS 1.2.0 RC2 now...
> > >> > all looks great... the dotnetviewer , the quey sample etc..etc..
> > >> > but, i got a problem with raster file.
> > >> > i'm using OSGeo GDAL raster provider..
> > >> > first step , i fill the "Default raster file location" field with
> > my
> > >> > raster
> > >> > file (*tif) folder path ("example:c:\image1")
> > >> > second step,.. test the connection.. works fine...
> > >> > third, save the feature dataset.
> > >> > next, when i create my layer, map and weblayout only shows blank..
> > >> > but the "initial map view" seems recognize the coordinate.
> > >> > so what's wrong...
> > >> > thankyou
> > >> > br,
> > >> > didit
> > >> > gis dev
> > >> > _______________________________________________
> > >> > mapguide-users mailing list
> > >> > mapguide-users at lists.osgeo.org
> > >> > http://lists.osgeo.org/mailman/listinfo/mapguide-users
> > >> View this message in context:
> > >> http://www.nabble.com/Raster-did-not-load-show-tf4118579s16610.html#a11741710
> > >> Sent from the MapGuide Users mailing list archive at Nabble.com.
> > > br,
> > > didit
> > http://www.nabble.com/Raster-did-not-load-show-tf4118579s16610.html#a11808912
> br,
> didit
br,
didit
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20070730/26c41a89/attachment.html
