[mapguide-users] Raster did not load/show
didit.s banuardi.n
didithoe at gmail.com
Mon Jul 30 01:54:44 EDT 2007
oke, next i'm testing it with ECW file,
to make it available for other to test the case.., i ' m using the "blue
marble" "ecw" file , available at demis.
http://support.demis.nl/files/3/demiswms/entry1337.aspx
the steps:
1.)download the ecw files (2,east and west) to
"c:\vhdBRDspatial\Bluemarble" directory
2.)download the ECW plugin from "http://home.gdal.org/dl/mapguide/"
(gdal_ecw_120.zip)
3.) copy the "gdalplugins" folder to "BIN" directory.
4.)restart the service
5.) RUN debug mode
5.)open the MG studio 2007 and build the datasource (Default
rasterfilelocation:c:\vhdBRDspatial\Bluemarble\)....layer...,map..., web
layout...
and still the image didn't show, only a dark blue image....
this is the debug result....
(note the red font...is it correct?)
<http://localhost:8008/mapguide/configbuilder.php>
C:\Program Files\MapGuideOpenSource\Server\Bin>set CPL_DEBUG=ON
C:\Program Files\MapGuideOpenSource\Server\Bin>mgserver STOP
Stopping the server service.
C:\Program Files\MapGuideOpenSource\Server\Bin>mgserver RUN
Running the server interactively as an application instead of as a service.
(460|2360) Server starting...
(460|2360) PROJ4 Coordinate System Library
(460|2360) Server started.
GDAL: Auto register C:\Program
Files\MapGuideOpenSource\Server\Bin\gdalplugins\g
dal_ECW.dll using GDALRegister_ECW.
ECW: Actually creating ECW driver.
ECW: OpenECW(C:\vhBRDspatial\BlueMarble\/land_shallow_topo_east.ecw)
ECW: Open(C:\vhBRDspatial\BlueMarble\/land_shallow_topo_east.ecw)
ECW:
NCScbmOpenFileView(C:\vhBRDspatial\BlueMarble\/land_shallow_topo_east.ecw):
eErr = 0
ECW: FileInfo: SizeXY=21600,21600 Bands=3
OriginXY=0,90 CellIncrementXY=0.00833333,-0.00833333
ECW: projection=RAW, datum=RAW
GDAL: GDALOpen(C:\vhBRDspatial\BlueMarble\/land_shallow_topo_east.ecw)
succeeds
as ECW.
ECW: OpenECW(C:\vhBRDspatial\BlueMarble\/land_shallow_topo_west.ecw)
ECW: Open(C:\vhBRDspatial\BlueMarble\/land_shallow_topo_west.ecw)
ECW:
NCScbmOpenFileView(C:\vhBRDspatial\BlueMarble\/land_shallow_topo_west.ecw):
eErr = 0
OriginXY=-180,90 CellIncrementXY=0.00833333,-0.00833333
GDAL: GDALOpen(C:\vhBRDspatial\BlueMarble\/land_shallow_topo_west.ecw)
succeeds
as ECW.
ECWRasterBand: RasterIO(nXOff=0,nYOff=10736,nXSize=60,nYSize=128 -> 533x566)
ECWRasterBand: RasterIO(nXOff=21540,nYOff=10736,nXSize=60,nYSize=128 ->
533x566)
533x566)
533x566)
br,
didit
On 7/26/07, ori gudes <ori at sinapistech.com> wrote:
> Hi
> Can you Verify if other formats work ? such as ECW or Mr' SID ? that can
> help you to know if it is a general problem or only at this format/file.
> Regards Ori
> didit.s banuardi.n wrote:
> > i'm inserting another layer on top and bottom of the layer raster,
> still
> > the raster layer didn''t show up...
> > but the "initial map view" shows the correct coordinate of raster layer.
> > fyi,
> > -i'm using MGOS 1.2.0 RC2, MGS 2007,AJAX dotnet viwer, Win 2003 Sp2 On
> > Virtual Server environment
> > -the raster layer size is 250 Mb, is it to big or not?
> > any suggest to debug the problem??
> > On 7/23/07, ori gudes <origu at omnitech.co.il> wrote:
> >> Hi
> >> Did you try to insert another layer (in t the Map) from the same
> >> geographical area on top of the raster ?
> >> Maybe it is just matter of coordinate's problems ?
> >> Regards Ori
> >> > hi,all
> >> > i'm testing the MGOS 1.2.0 RC2 now...
> >> > all looks great... the dotnetviewer , the quey sample etc..etc..
> >> > but, i got a problem with raster file.
> >> > i'm using OSGeo GDAL raster provider..
> >> > first step , i fill the "Default raster file location" field with my
> >> > raster
> >> > file (*tif) folder path ("example:c:\image1")
> >> > second step,.. test the connection.. works fine...
> >> > third, save the feature dataset.
> >> > next, when i create my layer, map and weblayout only shows blank..
> >> > but the "initial map view" seems recognize the coordinate.
> >> > so what's wrong...
> >> > thankyou
> >> > br,
> >> > didit
> >> > gis dev
> >> > _______________________________________________
> >> > mapguide-users mailing list
> >> > mapguide-users at lists.osgeo.org
> >> > http://lists.osgeo.org/mailman/listinfo/mapguide-users
> >> View this message in context:
> http://www.nabble.com/Raster-did-not-load-show-tf4118579s16610.html#a11741710
> >> Sent from the MapGuide Users mailing list archive at Nabble.com.
> > br,
> > didit
> http://www.nabble.com/Raster-did-not-load-show-tf4118579s16610.html#a11808912
br,
didit
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20070730/23cd6825/attachment.html
