[mapguide-users] Raster did not load/show
ori gudes ori at sinapistech.com
Thu Jul 26 07:43:16 EDT 2007
Hi
Can you Verify if other formats work ? such as ECW or Mr' SID  ? that can
help you to know if it is a general problem or only at this format/file.
Regards Ori
didit.s banuardi.n wrote:
> i'm  inserting another layer on top and bottom of the layer raster, still
> the raster layer didn''t show up...
> but the "initial map view" shows the correct coordinate of raster layer.
> fyi,
> -i'm using MGOS 1.2.0 RC2, MGS 2007,AJAX dotnet viwer, Win 2003 Sp2 On
> Virtual Server environment
> -the raster layer size is 250 Mb, is it to big or not?
> any suggest to debug the problem??
> On 7/23/07, ori gudes <origu at omnitech.co.il> wrote:
>> Hi
>> Did you try to insert another layer (in t the Map) from the same
>> geographical area on top of the raster ?
>> Maybe it is just matter of coordinate's problems ?
>> Regards Ori
>> > hi,all
>> > i'm testing the MGOS 1.2.0 RC2 now...
>> > all looks great... the dotnetviewer , the quey sample etc..etc..
>> > but, i got a problem with raster file.
>> > i'm using OSGeo GDAL raster provider..
>> > first step , i fill the "Default raster file location" field with my
>> > raster
>> > file (*tif) folder path  ("example:c:\image1")
>> > second step,.. test the connection.. works fine...
>> > third, save the feature dataset.
>> > next, when i create my layer, map and weblayout only shows blank..
>> > but the "initial map view" seems recognize the coordinate.
>> > so what's wrong...
>> > thankyou
>> > br,
>> > didit
>> > gis dev
>> > _______________________________________________
>> > mapguide-users mailing list
>> > mapguide-users at lists.osgeo.org
>> > http://lists.osgeo.org/mailman/listinfo/mapguide-users
>> View this message in context:
>> http://www.nabble.com/Raster-did-not-load-show-tf4118579s16610.html#a11741710
>> Sent from the MapGuide Users mailing list archive at Nabble.com.
> br,
> didit
View this message in context: http://www.nabble.com/Raster-did-not-load-show-tf4118579s16610.html#a11808912
