[mapguide-users] MG v1.1.0 Install on Win XP Problem
Nimrod Cnaan
nimcnaan at hotmail.com
Mon Jul 30 16:46:27 EDT 2007
This is a known issu, you only need to Repair the Microsoft .NET framework 2.0 installation to its original state from the Add/Remove programs.
From: xetec at hotmail.comTo: mapguide-users at lists.osgeo.orgDate: Mon, 30 Jul 2007 12:06:25 -0700Subject: [mapguide-users] MG v1.1.0 Install on Win XP Problem
I'm sure someone has encounter something like this. I could use some installation help.
We have version 1.02 running on our server, but then decided to test out the newer versions for MG server on some test computers, which are all Win XP Pro. I have installed IIS v5.1 on them and installed MG 1.1.0. Everything seems to work OK until I install the sample data. I'm able to log into the server remotely to view the web studio & the site admin, trying the view the sample data remotely causes an error.
The next step was trying the view the data, via web browser, from the server computer. This is what I get for an error (listed below):
Server Error in '/mapguide' Application.
Failed to access IIS metabase.
Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code. Exception Details: System.Web.Hosting.HostingEnvironmentException: Failed to access IIS metabase. The process account used to run ASP.NET must have read access to the IIS metabase (e.g. IIS://servername/W3SVC). For information on modifying metabase permissions, please see http://support.microsoft.com/?kbid=267904.Source Error:
An unhandled exception was generated during the execution of the current web request. Information regarding the origin and location of the exception can be identified using the exception stack trace below.
Stack Trace:
[HostingEnvironmentException: Failed to access IIS metabase.]
System.Web.Configuration.MetabaseServerConfig.MapPathCaching(String siteID, VirtualPath path) +3609834
System.Web.Configuration.MetabaseServerConfig.System.Web.Configuration.IConfigMapPath2.MapPath(String siteID, VirtualPath vpath) +9
System.Web.Hosting.HostingEnvironment.MapPathActual(VirtualPath virtualPath, Boolean permitNull) +169
System.Web.CachedPathData.GetConfigPathData(String configPath) +382
System.Web.CachedPathData.GetConfigPathData(String configPath) +243
System.Web.CachedPathData.GetApplicationPathData() +68
System.Web.CachedPathData.GetVirtualPathData(VirtualPath virtualPath, Boolean permitPathsOutsideApp) +3503459
System.Web.Configuration.RuntimeConfig.GetLKGRuntimeConfig(VirtualPath path) +189
Version Information: Microsoft .NET Framework Version:2.0.50727.832; ASP.NET Version:2.0.50727.832
What am I doing wrong? (Thanks for the help)
_________________________________________________________________
Make every IM count. Download Windows Live Messenger and join the i’m Initiative now. It’s free.
http://im.live.com/messenger/im/home/?source=TAGWL_June07
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20070730/ef611b48/attachment.html
