[mapguide-users] Data connection to raster...
Rich Bauer rdbauer at gmail.com
Mon Jul 30 17:02:29 EDT 2007
Ben,
I had that same problem just about an hour ago.  I have the same version
as you but not same setup, no VMWare, Windows XP and full version of
Studio.  What I do when that happens is I close down MapGuide Studio and
go in and restart the mgserver service under the admin tools for
windows.  Then just start up studio and everything is fine.  I don't
know if there is a fix, but this is the "work around" I use.  Hope it helps.
Rich
Ben_D wrote:
> Hi,
> I'm trying to get MrSID rasters to show in MapGuide. I've had them working
> without a problem, but keep getting the same error when I attempt to make a
> data connection on a new set up. I'm working in VMware running Windows 2003
> Server and Apache. Both setup's are identical (ie - two copies of the same
> virtual machine) and I am using the patched trial version of Autodesk
> MapGuide Studio.
> I have triple checked the install process for MrSID support (The
> MapGuide1.1.0_GDAL patch and the two patches from
> http://home.gdal.org/dl/mapguide/ (mg_fdogdal_110 and mg_mrsid_110) and
> followed the same process on both setups.
> The only difference is that when I use the "Test Connection" on the computer
> that won't show the MrSIDs I get the following error:
> Resource was not found:
> Session:5c15fb9e-0000-1000-8000-000c29375b51_en//FeatureSourceEditorsScratch/SessionVersion6.FeatureSource
> Obviously the session number changes each time. Whats weird is that when I
> set up a data connection and test it, I dont get the error message. But as
> soon as I make a layer, the error message appears and nothing shows in the
> web layout. The resource is is sitting in the right location (C:\Documents
> and Settings\Administrator\Desktop\Projected\c01c.sid) and works on an
> identical set up.
> I'm pulling my hair out trying to solve this so any help would be
> appreciated!
> Thanks!
