SPAM-LOW: Re: [mapguide-users] Data connection to raster...
Andy Morsell
amorsell at spatialgis.com
Mon Jul 30 17:31:11 EDT 2007
Wanted to relate that I have the same problem in Studio. Creating a GDAL
data connection, then changing it in some way, causes this error until
mapguide server is restarted. Creating new GDAL data connections will
continue to work fine, it's only altering existing ones where I've seen this
problem occur.
Andy Morsell, P.E.
Spatial Integrators, Inc.
http://www.SpatialGIS.com
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Rich Bauer
Sent: Monday, July 30, 2007 2:02 PM
To: MapGuide Users Mail List
Subject: SPAM-LOW: Re: [mapguide-users] Data connection to raster...
Ben,
I had that same problem just about an hour ago. I have the same version as
you but not same setup, no VMWare, Windows XP and full version of Studio.
What I do when that happens is I close down MapGuide Studio and go in and
restart the mgserver service under the admin tools for windows. Then just
start up studio and everything is fine. I don't know if there is a fix, but
this is the "work around" I use. Hope it helps.
Rich
Ben_D wrote:
> Hi,
> I'm trying to get MrSID rasters to show in MapGuide. I've had them working
> without a problem, but keep getting the same error when I attempt to make
a
> data connection on a new set up. I'm working in VMware running Windows
2003
> Server and Apache. Both setup's are identical (ie - two copies of the same
> virtual machine) and I am using the patched trial version of Autodesk
> MapGuide Studio.
> I have triple checked the install process for MrSID support (The
> MapGuide1.1.0_GDAL patch and the two patches from
> http://home.gdal.org/dl/mapguide/ (mg_fdogdal_110 and mg_mrsid_110) and
> followed the same process on both setups.
> The only difference is that when I use the "Test Connection" on the
computer
> that won't show the MrSIDs I get the following error:
> Resource was not found:
Session:5c15fb9e-0000-1000-8000-000c29375b51_en//FeatureSourceEditorsScratch
/SessionVersion6.FeatureSource
> Obviously the session number changes each time. Whats weird is that when I
> set up a data connection and test it, I dont get the error message. But as
> soon as I make a layer, the error message appears and nothing shows in the
> web layout. The resource is is sitting in the right location (C:\Documents
> and Settings\Administrator\Desktop\Projected\c01c.sid) and works on an
> identical set up.
> I'm pulling my hair out trying to solve this so any help would be
> appreciated!
> Thanks!
mapguide-users mailing list
mapguide-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-users
