[mapguide-users] How Can I load SDF
akramany
asm at cad-gis.com
Sat Jul 28 04:28:58 EDT 2007
Thank you Mr.Kenneth , I had added all DLLs in VB.NET reference from MapGuide
installation's FDO folder but the same error still there , I think this
maybe happened because I'm using trial version of Mapguide or what ?!
Kenneth, GEOGRAF A/S wrote:
> There are a number of Dll's that are needed for FDO to work.
> You should ALL the files from a working MapGuide installation's FDO
> folder,
> into the folder you reference the .Net wrapper from.
> The error 0x8007007E means "File not found",
> indicating that you are missing some files.
> As to the error with Studio; the load procedure is mostly unrelated
> to the MapGuide server, so you should ask Autodesk about that problem.
> There is no need/way to register the FDO dll's as they are not ActiveX
> dll's.
> Regards, Kenneth, GEOGRAF A/S
> akramany skrev:
>> When I import FDO as a reference in VB.NET and connect to SDF database
>> format
>> I have continual error (Exception from HRESULT: 0x8007007E) .
>> Also I have continual error (Exception from HRESULT: 0×800700c1) when I
>> load
>> SDF or SHP data with Autodesk MapGuide studio , this problem since one
>> month
>> I don’t reach to the solution , kindly I would like to get the right
>> solution in this matter if any one know .
>> How can I Register FDO DLL ?!!
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
View this message in context: http://www.nabble.com/How-Can-I-load-SDF-tf4151735s16610.html#a11840679
