[mapguide-users] SID Raster Problem
Rich Bauer
rdbauer at gmail.com
Fri Jun 1 12:46:10 EDT 2007
Thank you Andy and Jason. Yes I do have the GDAL files in the correct
place (C:\Program
Files\MapGuideOpenSource\Server\Bin\gdalplugins\gdal_MrSID.dll) and
(C:\Program Files\MapGuideOpenSource\Server\Bin\FDO\gdal13.dll). In
interactive mode, I get the following when going from creating a Data
Connection through adding it to a layout:
(6104|4620) Server starting...
(6104|4620) PROJ4 Coordinate System Library
(6104|4620) Server started.
ERROR 1: Can't load requested DLL: C:\Program
GDAL: GDALOpen(C:\Program
Files\MapGuideOpenSource\WebServerExtensions\www\Ortho
Imagery\ortho_imagery_MDOQNRCS_479326_05\ortho_imagery\Test1/ortho1-1_s_il141.au
x) succeeds as HFA.
x) succeeds as HFA.
x) succeeds as HFA.
x) succeeds as HFA.
x) succeeds as HFA.
x) succeeds as HFA.
x) succeeds as HFA.
GDAL: RasterIO() skipped for odd window or buffer size.
Window = (0,4681410)x-271143x-4637207
Buffer = 936x246
x) succeeds as HFA.
Buffer = 936x246
x) succeeds as HFA.
x) succeeds as HFA.
x) succeeds as HFA.
x) succeeds as HFA.
ERROR 1: Can't find RasterDMS field in Eimg_Layer with block list.
ERROR 1: IReadBlock failed at X offset 0, Y offset 0
x) succeeds as HFA.
x) succeeds as HFA.
x) succeeds as HFA.
(6104|5432) Permission denied to resource:
Session:e69838e2-ffff-ffff-8000-00505
6c00001_en//WebLayout7.WebLayout
Exception occurred in method
MgSessionResourceContentManager.CheckPermission at
line 239 in file
c:\build_bond_area\mapguide_open_source\build_3.1\mgdev\server\
src\services\resource\SessionResourceContentManager.cpp
x) succeeds as HFA.
x) succeeds as HFA.
x) succeeds as HFA.
(6104|3844) Permission denied to resource:
line 239 in file
x) succeeds as HFA.
x) succeeds as HFA.
I noticed right away the can't load requested DLL of the plugin. Umm???
Thanks for the help.
Rich
Andy Morsell wrote:
> Can you confirm that you have the GDAL files in the correct place? Under
> bin do you have a gdalplugins folder with the gdal_MrSID.dll file? In the
> FDO folder, do you have the gdal13.dll file? Do you have any entries in
> your log file indicating an FDO provider error? Have you tried running the
> server in interactive mode to see if you can see the problem?
> http://wiki.osgeo.org/index.php/MapGuide_Open_Source_Using_the_Open_Source_R
> aster_Provider_with_Studio
> Andy Morsell, P.E.
> Spatial Integrators, Inc.
> http://www.SpatialGIS.com
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Rich Bauer
> Sent: Friday, June 01, 2007 8:58 AM
> To: mapguide-users at lists.osgeo.org
> Subject: [mapguide-users] SID Raster Problem
> Hi All,
> I have looked all over, and cannot find the answer to my problem. If this
> has been answered before, please direct me to the post.
> My problem is I cannot get my raster SID, or even TIFF images, to load.
> I am running MGOS 1.1.0, on Windows XP, using Studio7 with SP1, PHP, and
> IIS. I have also applied the patch for studio and put the mg_mrsid_110
> stuff in the Bin on the server (actually my computer due to development but
> in the server portion). I am using the OSGeo.Gdal provider, have tried
> having only one image in a folder, have tried having all the images in a
> folder, have tried having the one image with all the data files included in
> one folder, have tried all of the above with putting the data files in the
> "Data files:" location of the Generic Editor, done several different
> coordinate combinations including zooming out a ridiculous amount to see if
> the coordinate stuff was incorrect, but nothing. I am at whits end here.
> Help please!!
> Maybe I did the updates and patches wrong or something, if someone has a
> "Step-by-step" type procedure for updating the server and that from the
> install of the MGServer 1.1.0, that would be great, including FDO mainly for
> Raster.
> Thanks
> Rich
> mapguide-users mailing list
