[mapguide-users] Mapguide on Fedora Core 4
Stefan Grote stefan at mail.swiftos.de
Sun Jun 3 10:04:22 EDT 2007
Hi Guys,
currently i try to install Mapguide on my Fedora Core 4 (after compile
problem on my Debian etch, i will try it on a Fedora Core 4 because, i
read it will work.)
But now i get the same errors like under Debian Etch:
cc1plus: warning: command line option "-Wstrict-prototypes" is valid for
Ada/C/ObjC but not for C++
BOpcodeHandler.cpp:52:29: error: jpeglib.h: No such file or directory
BOpcodeHandler.cpp:4970: error: field 'jerr' has incomplete type
BOpcodeHandler.cpp:4976: error: variable or field 'my_jpeg_messages'
declared void
BOpcodeHandler.cpp:4976: error: 'j_common_ptr' was not declared in this
scope
BOpcodeHandler.cpp:4976: error: expected ',' or ';' before '{' token
BOpcodeHandler.cpp:4984: error: variable or field 'my_jpeg_error'
declared void
BOpcodeHandler.cpp:4984: error: 'j_common_ptr' was not declared in this
scope
BOpcodeHandler.cpp:4984: error: expected ',' or ';' before '{' token
BOpcodeHandler.cpp:4999: error: variable or field 'init_destination'
declared void
<much more errors>
BOpcodeHandler.cpp:5411: error: 'jpeg_destroy_decompress' was not
declared in this scope
make[3]: *** [BOpcodeHandler.lo] Fehler 1
make[3]: Leaving directory
`/root/mapguide-1.1.0/Oem/DWFTK7.1/develop/global/src/dwf/w3dtk'
make[2]: *** [all-recursive] Fehler 1
make[2]: Leaving directory
make[1]: *** [all-recursive] Fehler 1
make[1]: Leaving directory
`/root/mapguide-1.1.0/Oem/DWFTK7.1/develop/global/src/dwf'
make: *** [all] Fehler 2
DWFTK 7.1: Error build failed (0).................
Does anybody know how to solve?
Thanks,
Stefan
