[mapguide-users] Mapguide on Fedora Core 4
Walt Welton-Lair walt.welton-lair at autodesk.com
Sun Jun 3 10:17:35 EDT 2007
Is the JPEG library installed on your machine?  It's required...  See http://mapguide.osgeo.org/1.2/docs/BuildInstallQuickStartLinux.html.
	-----Original Message-----
	From: mapguide-users-bounces at lists.osgeo.org on behalf of Stefan Grote
	Sent: Sun 6/3/2007 4:04 PM
	To: MapGuide Users Mail List
	Cc:
	Subject: [mapguide-users] Mapguide on Fedora Core 4
	Hi Guys,
	currently i try to install Mapguide on my Fedora Core 4 (after compile
	problem on my Debian etch, i will try it on a Fedora Core 4 because, i
	read it will work.)
	But now i get the same errors like under Debian Etch:
	cc1plus: warning: command line option "-Wstrict-prototypes" is valid for
	Ada/C/ObjC but not for C++
	BOpcodeHandler.cpp:52:29: error: jpeglib.h: No such file or directory
	BOpcodeHandler.cpp:4970: error: field 'jerr' has incomplete type
	BOpcodeHandler.cpp:4976: error: variable or field 'my_jpeg_messages'
	declared void
	BOpcodeHandler.cpp:4976: error: 'j_common_ptr' was not declared in this
	scope
	BOpcodeHandler.cpp:4976: error: expected ',' or ';' before '{' token
	BOpcodeHandler.cpp:4984: error: variable or field 'my_jpeg_error'
	declared void
	BOpcodeHandler.cpp:4984: error: 'j_common_ptr' was not declared in this
	scope
	BOpcodeHandler.cpp:4984: error: expected ',' or ';' before '{' token
	BOpcodeHandler.cpp:4999: error: variable or field 'init_destination'
	declared void
	<much more errors>
	BOpcodeHandler.cpp:5411: error: 'jpeg_destroy_decompress' was not
	declared in this scope
	make[3]: *** [BOpcodeHandler.lo] Fehler 1
	make[3]: Leaving directory
	`/root/mapguide-1.1.0/Oem/DWFTK7.1/develop/global/src/dwf/w3dtk'
	make[2]: *** [all-recursive] Fehler 1
	make[2]: Leaving directory
	make[1]: *** [all-recursive] Fehler 1
	make[1]: Leaving directory
	`/root/mapguide-1.1.0/Oem/DWFTK7.1/develop/global/src/dwf'
	make: *** [all] Fehler 2
	DWFTK 7.1: Error build failed (0).................
	Does anybody know how to solve?
	Thanks,
	Stefan
	mapguide-users mailing list
	mapguide-users at lists.osgeo.org
	http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20070603/144a86fa/attachment.html
