[mapguide-users] Mapguide on Fedora Core 4
Chris Gountanis cgountanis at mpower-tech.com
Sun Jun 3 14:12:55 EDT 2007
Works perfectly on CentOS 4.5. I have not tried CentOS 5 but that is with
a newer GCC so I would not try it unless your bored.
CentOS of course is RedHat Enterprise and fully STILL supported with one
command (yum update) your full up-to-date.
Hit me up if you want a look at my notes including YUM commands, depends
and basic setup. The MG install went perfectly with no code tweaks. I was
even able to help build with new java.i files and test the new Java API.
CentOS seems to be the new supported platform... at least that is what I
have head from Autodesk. Very happy with it overall!
Chris
On Sun, June 3, 2007 9:17 am, Walt Welton-Lair wrote:
> Is the JPEG library installed on your machine?  It's required...  See
> http://mapguide.osgeo.org/1.2/docs/BuildInstallQuickStartLinux.html.
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org on behalf of Stefan Grote
> Sent: Sun 6/3/2007 4:04 PM
> To: MapGuide Users Mail List
> Cc:
> Subject: [mapguide-users] Mapguide on Fedora Core 4
> Hi Guys,
> currently i try to install Mapguide on my Fedora Core 4 (after compile
> problem on my Debian etch, i will try it on a Fedora Core 4 because, i
> read it will work.)
> But now i get the same errors like under Debian Etch:
> cc1plus: warning: command line option "-Wstrict-prototypes" is valid for
> Ada/C/ObjC but not for C++
> BOpcodeHandler.cpp:52:29: error: jpeglib.h: No such file or directory
> BOpcodeHandler.cpp:4970: error: field 'jerr' has incomplete type
> BOpcodeHandler.cpp:4976: error: variable or field 'my_jpeg_messages'
> declared void BOpcodeHandler.cpp:4976: error: 'j_common_ptr' was not
> declared in this scope BOpcodeHandler.cpp:4976: error: expected ',' or ';'
> before '{' token BOpcodeHandler.cpp:4984: error: variable or field
> 'my_jpeg_error'
> declared void BOpcodeHandler.cpp:4984: error: 'j_common_ptr' was not
> declared in this scope BOpcodeHandler.cpp:4984: error: expected ',' or ';'
> before '{' token BOpcodeHandler.cpp:4999: error: variable or field
> 'init_destination'
> declared void
> <much more errors>
> BOpcodeHandler.cpp:5411: error: 'jpeg_destroy_decompress' was not
> declared in this scope make[3]: *** [BOpcodeHandler.lo] Fehler 1
> make[3]: Leaving directory
> `/root/mapguide-1.1.0/Oem/DWFTK7.1/develop/global/src/dwf/w3dtk'
> make[2]: *** [all-recursive] Fehler 1
> make[2]: Leaving directory
> make[1]: *** [all-recursive] Fehler 1
> make[1]: Leaving directory
> `/root/mapguide-1.1.0/Oem/DWFTK7.1/develop/global/src/dwf'
> make: *** [all] Fehler 2
> DWFTK 7.1: Error build failed (0).................
> Does anybody know how to solve?
> Thanks,
> Stefan
> mapguide-users mailing list mapguide-users at lists.osgeo.org
