[mapguide-users] Problem with legend - style
martijni mis at gemeentehulst.nl
Mon Jun 4 11:36:30 EDT 2007
Kenneth,
Thanks for your reaction.
I uploaded the xml file for you. Take a look at it. I did a validation check
and received no errors.
As far as I can see it's using UTF-8. Maybe i'm wrong ofcourse.... :)
Kenneth, GEOGRAF A/S wrote:
> That probably means that the document you upload does not validate
> according to the XSD schema.
> You can find the XSD Schema's in the "Schema" folder where you installed
> MapGuide.
> There are free xml validators on the web, that will give you more detail
> on what went wrong.
> Be aware that there is a different schema for each resource type.
> Also, you MUST use UTF-8 encoding (it will not give the above error, but
> won't display the map).
> Regards, Kenneth, GEOGRAF A/S
> martijni wrote:
>> James,
>> I doubt that I misstyped the resource ID, because I tried different
>> resource
>> ID's to make sure it wasn't a typo. Each time I receive this exception:
>> An exception occurred in the XML parser.
>> An exception occurred in the XML parser. Exception occurred in method
>> MgResourceContentManager.ValidateDocument at line 586 in file
>> c:\build_bond_area\mapguide_open_source\build_3.1\mgdev\server\src\services\resource\ResourceContentManager.cpp
>> Don't know if this gives you some more information...?
>> James Card wrote:
>>> On Fri, 01 Jun 2007 06:48:01 -0700, martijni <mis at gemeentehulst.nl>
>>> wrote:
>>>> I understand what you say, but do I have to reload the XML using the
>>>> mapagent interface like this way:
>>>> Resource --> SetResource --> Resource ID is location where the file
>>>> will
>>>> be placed
>>>> Content is the location of the xml file
>>>> Header is empty
>>>> But when I did it this way I received an exception. Is this the way you
>>>> should do it, or did you mean something else?
>>> That is exactly the procedure we use here. Did you mistype the Resource
>>> ID? Is your XML file valid?
>>> James Card
>>> California CAD Solutions, Inc.
>>> 209 578-5580
>>> mapguide-users mailing list
>>> mapguide-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
http://www.nabble.com/file/p10952225/tanks.LayerDefinition.xml
View this message in context: http://www.nabble.com/Problem-with-legend---style-tf3847021s16610.html#a10952225
