[mapguide-users] Problem with legend - style
Kenneth, GEOGRAF A/S ks at geograf.dk
Mon Jun 4 12:35:39 EDT 2007
I've tried validating it. I validates fine for me.
I can also upload it using the test form. It shows in studio, but I
don't have the featuresource.
It would appear that the XSD files are broken in your install, or
something happened when you posted and I downloaded.
If possible, try uninstalling, remove the entire folder C:\Program
Files\MapGuideOpenSource, and reinstall.
Remember to backup any data you want to save. You might use the package
manager in the site admin for this purpose.
I was using MapGuide 1.2 Beta 2 for my testing.
Regards, Kenneth, GEOGRAF A/S
martijni wrote:
> Kenneth,
> Thanks for your reaction.
> I uploaded the xml file for you. Take a look at it. I did a validation check
> and received no errors.
> As far as I can see it's using UTF-8. Maybe i'm wrong ofcourse.... :)
> Kenneth, GEOGRAF A/S wrote:
>> That probably means that the document you upload does not validate
>> according to the XSD schema.
>> You can find the XSD Schema's in the "Schema" folder where you installed
>> MapGuide.
>> There are free xml validators on the web, that will give you more detail
>> on what went wrong.
>> Be aware that there is a different schema for each resource type.
>> Also, you MUST use UTF-8 encoding (it will not give the above error, but
>> won't display the map).
>> martijni wrote:
>>> James,
>>> I doubt that I misstyped the resource ID, because I tried different
>>> resource
>>> ID's to make sure it wasn't a typo. Each time I receive this exception:
>>> An exception occurred in the XML parser.
>>> An exception occurred in the XML parser. Exception occurred in method
>>> MgResourceContentManager.ValidateDocument at line 586 in file
>>> c:\build_bond_area\mapguide_open_source\build_3.1\mgdev\server\src\services\resource\ResourceContentManager.cpp
>>> Don't know if this gives you some more information...?
>>> James Card wrote:
>>>> On Fri, 01 Jun 2007 06:48:01 -0700, martijni <mis at gemeentehulst.nl>
>>>> wrote:
>>>>> I understand what you say, but do I have to reload the XML using the
>>>>> mapagent interface like this way:
>>>>> Resource --> SetResource --> Resource ID is location where the file
>>>>> will
>>>>> be placed
>>>>> Content is the location of the xml file
>>>>> Header is empty
>>>>> But when I did it this way I received an exception. Is this the way you
>>>>> should do it, or did you mean something else?
>>>> That is exactly the procedure we use here. Did you mistype the Resource
>>>> ID? Is your XML file valid?
>>>> James Card
>>>> California CAD Solutions, Inc.
>>>> 209 578-5580
>>>> _______________________________________________
>>>> mapguide-users mailing list
>>>> mapguide-users at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
> http://www.nabble.com/file/p10952225/tanks.LayerDefinition.xml
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20070604/5a69d687/attachment.html
