[mapguide-users] Problem with legend - style
Kenneth, GEOGRAF A/S
ks at geograf.dk
Mon Jun 4 12:46:45 EDT 2007
I can get a similar exception if I type in
Library://tank.MapDefinition
as the resource id, if I type:
Library://tank.LayerDefinition
it all goes fine.
Regards, Kenneth, GEOGRAF A/S
Kenneth, GEOGRAF A/S wrote:
> I've tried validating it. I validates fine for me.
> I can also upload it using the test form. It shows in studio, but I
> don't have the featuresource.
> It would appear that the XSD files are broken in your install, or
> something happened when you posted and I downloaded.
> If possible, try uninstalling, remove the entire folder C:\Program
> Files\MapGuideOpenSource, and reinstall.
> Remember to backup any data you want to save. You might use the
> package manager in the site admin for this purpose.
> I was using MapGuide 1.2 Beta 2 for my testing.
> martijni wrote:
>> Kenneth,
>> Thanks for your reaction.
>> I uploaded the xml file for you. Take a look at it. I did a validation check
>> and received no errors.
>> As far as I can see it's using UTF-8. Maybe i'm wrong ofcourse.... :)
>>> That probably means that the document you upload does not validate
>>> according to the XSD schema.
>>> You can find the XSD Schema's in the "Schema" folder where you installed
>>> MapGuide.
>>> There are free xml validators on the web, that will give you more detail
>>> on what went wrong.
>>> Be aware that there is a different schema for each resource type.
>>> Also, you MUST use UTF-8 encoding (it will not give the above error, but
>>> won't display the map).
>>> martijni wrote:
>>>> James,
>>>> I doubt that I misstyped the resource ID, because I tried different
>>>> resource
>>>> ID's to make sure it wasn't a typo. Each time I receive this exception:
>>>> An exception occurred in the XML parser.
>>>> An exception occurred in the XML parser. Exception occurred in method
>>>> MgResourceContentManager.ValidateDocument at line 586 in file
>>>> c:\build_bond_area\mapguide_open_source\build_3.1\mgdev\server\src\services\resource\ResourceContentManager.cpp
>>>> Don't know if this gives you some more information...?
>>>> James Card wrote:
>>>>> On Fri, 01 Jun 2007 06:48:01 -0700, martijni <mis at gemeentehulst.nl>
>>>>> wrote:
>>>>>> I understand what you say, but do I have to reload the XML using the
>>>>>> mapagent interface like this way:
>>>>>> Resource --> SetResource --> Resource ID is location where the file
>>>>>> will
>>>>>> be placed
>>>>>> Content is the location of the xml file
>>>>>> Header is empty
>>>>>> But when I did it this way I received an exception. Is this the way you
>>>>>> should do it, or did you mean something else?
>>>>> That is exactly the procedure we use here. Did you mistype the Resource
>>>>> ID? Is your XML file valid?
>>>>> James Card
>>>>> California CAD Solutions, Inc.
>>>>> 209 578-5580
>>>>> _______________________________________________
>>>>> mapguide-users mailing list
>>>>> mapguide-users at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>> http://www.nabble.com/file/p10952225/tanks.LayerDefinition.xml
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20070604/64591769/attachment.html
