[mapguide-users] Problem with legend - style
martijni mis at gemeentehulst.nl
Tue Jun 5 02:42:53 EDT 2007
Kenneth,
I feel pretty stupid right now... Instead of defining the Layerdefinition I
always gave as resource FeatureSource :x
So I'm thanking you for the last post for what you've typed in. It's working
now. My only question left is that when I remove the style types, that
shouldn't be seen in the legend and upload it like we did now, and the
information in the accesdatabase gets updated this automatic changes in the
viewer. Or do you have to update the LayerDefinition each time?
Thanks for the help!
Kenneth, GEOGRAF A/S wrote:
> I can get a similar exception if I type in
> Library://tank.MapDefinition
> as the resource id, if I type:
> Library://tank.LayerDefinition
> it all goes fine.
> Regards, Kenneth, GEOGRAF A/S
>> I've tried validating it. I validates fine for me.
>> I can also upload it using the test form. It shows in studio, but I
>> don't have the featuresource.
>> It would appear that the XSD files are broken in your install, or
>> something happened when you posted and I downloaded.
>> If possible, try uninstalling, remove the entire folder C:\Program
>> Files\MapGuideOpenSource, and reinstall.
>> Remember to backup any data you want to save. You might use the
>> package manager in the site admin for this purpose.
>> I was using MapGuide 1.2 Beta 2 for my testing.
>> martijni wrote:
>>> Kenneth,
>>> Thanks for your reaction.
>>> I uploaded the xml file for you. Take a look at it. I did a validation
>>> check
>>> and received no errors.
>>> As far as I can see it's using UTF-8. Maybe i'm wrong ofcourse.... :)
>>>> That probably means that the document you upload does not validate
>>>> according to the XSD schema.
>>>> You can find the XSD Schema's in the "Schema" folder where you
>>>> installed
>>>> MapGuide.
>>>> There are free xml validators on the web, that will give you more
>>>> detail
>>>> on what went wrong.
>>>> Be aware that there is a different schema for each resource type.
>>>> Also, you MUST use UTF-8 encoding (it will not give the above error,
>>>> but
>>>> won't display the map).
>>>> martijni wrote:
>>>>> James,
>>>>> I doubt that I misstyped the resource ID, because I tried different
>>>>> resource
>>>>> ID's to make sure it wasn't a typo. Each time I receive this
>>>>> exception:
>>>>> An exception occurred in the XML parser.
>>>>> An exception occurred in the XML parser. Exception occurred in method
>>>>> MgResourceContentManager.ValidateDocument at line 586 in file
>>>>> c:\build_bond_area\mapguide_open_source\build_3.1\mgdev\server\src\services\resource\ResourceContentManager.cpp
>>>>> Don't know if this gives you some more information...?
>>>>> James Card wrote:
>>>>>> On Fri, 01 Jun 2007 06:48:01 -0700, martijni <mis at gemeentehulst.nl>
>>>>>> wrote:
>>>>>>> I understand what you say, but do I have to reload the XML using the
>>>>>>> mapagent interface like this way:
>>>>>>> Resource --> SetResource --> Resource ID is location where the file
>>>>>>> will
>>>>>>> be placed
>>>>>>> Content is the location of the xml file
>>>>>>> Header is empty
>>>>>>> But when I did it this way I received an exception. Is this the way
>>>>>>> you
>>>>>>> should do it, or did you mean something else?
>>>>>> That is exactly the procedure we use here. Did you mistype the
>>>>>> Resource
>>>>>> ID? Is your XML file valid?
>>>>>> James Card
>>>>>> California CAD Solutions, Inc.
>>>>>> 209 578-5580
>>>>>> _______________________________________________
>>>>>> mapguide-users mailing list
>>>>>> mapguide-users at lists.osgeo.org
>>>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>>> http://www.nabble.com/file/p10952225/tanks.LayerDefinition.xml
View this message in context: http://www.nabble.com/Problem-with-legend---style-tf3847021s16610.html#a10964221
