[mapguide-users] Several small lay-out questions
Jackie Ng jackie.ng at aecsystems.com.au
Thu Jun 7 04:37:05 EDT 2007
Regarding the decimals, try using 0+<property name> as your expression.
- Jackie
martijni wrote:
> Hey,
> I'm facing some small lay-out problems that I want to get rid of.
> As you can see on the screenshot it shows for numbers, six decimals, but
> ofcourse it should show none. Same for the date when it shows TIMESTAMP
> and the hours after the date, while it isn't supposed to show up. Further
> in the legend it shows a red cross when you chooce to not show a style of
> the geometry, but just the feature label. How can you turn this red cross
> into something like "abc" or at least into something else.
> Last question is how to make the selection area bigger for an image. Like
> the symbol you see that's selected on the screenshot, it has to be clicked
> totally on the right side of it before it's selected.
>  http://www.nabble.com/file/p11003274/decimalenendate.jpg
> If anyone could help me solve these problems, wich are probably easy for
> some experts of you, I would appreciate! :)
> Thanks in advance.
> Martijn
View this message in context: http://www.nabble.com/Several-small-lay-out-questions-tf3882273s16610.html#a11004105
