[mapguide-users] Several small lay-out questions
martijni mis at gemeentehulst.nl
Thu Jun 7 04:46:14 EDT 2007
Thanks for your reply Jackie.
I could be wrong, but what you're saying, shouldn't that be filled in the
tooltip and has no effect on the properties...?
Jackie Ng wrote:
> Regarding the decimals, try using 0+<property name> as your expression.
> - Jackie
> martijni wrote:
>> Hey,
>> I'm facing some small lay-out problems that I want to get rid of.
>> As you can see on the screenshot it shows for numbers, six decimals, but
>> ofcourse it should show none. Same for the date when it shows TIMESTAMP
>> and the hours after the date, while it isn't supposed to show up. Further
>> in the legend it shows a red cross when you chooce to not show a style of
>> the geometry, but just the feature label. How can you turn this red cross
>> into something like "abc" or at least into something else.
>> Last question is how to make the selection area bigger for an image. Like
>> the symbol you see that's selected on the screenshot, it has to be
>> clicked totally on the right side of it before it's selected.
>>  http://www.nabble.com/file/p11003274/decimalenendate.jpg
>> If anyone could help me solve these problems, wich are probably easy for
>> some experts of you, I would appreciate! :)
>> Thanks in advance.
>> Martijn
View this message in context: http://www.nabble.com/Several-small-lay-out-questions-tf3882273s16610.html#a11004184
