[mapguide-users] Display layer based on filter/query results
nicholda nicholda at talgov.com
Thu Jun 7 11:18:19 EDT 2007
Thanks, I will give it a try.
RichBauer wrote:
> I have not done this specific thing you are talking about, but I think
> that you might be able to start with the code at
> http://data.mapguide.com/mapguide/gt/index.php and modify it for your
> specific needs.  On the right hand side of the screen is where you can
> download the source code.  Hope it helps.
> Rich
> nicholda wrote:
>> Does anyone know if it's possible to display a data for a layer based on
>> a
>> dynamic filter or layer?  I want to create a dynamic search tool that a
>> user
>> can select data based on date and only display the data returned from the
>> users criteria.  Has anyone done this before, if so could you please help
>> to
>> point me in the right direction?  If you have any source code it would be
>> much appreciatted.
>> Thanks,
>> David
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
View this message in context: http://www.nabble.com/Display-layer-based-on-filter-query-results-tf3884070s16610.html#a11010024
