AW: [mapguide-users] creating points at runtime / display problem
G.E.O.-Consulting / Hans Mörschell moerschell at geo.co.at
Fri Jun 8 04:37:23 EDT 2007
Hi Jackie,
I do not succeed in displaying any geometry that I create at runtime; I
tested the dotnetviewer sample with the newest files and datasets,
controlled what has been written in the ticket, but there is no point shown
in display, not in my own application nor in the sample.
At the moment I can't imagine what I am doing wrong,
any other suggestion ??
kind regards, Hans
-----Ursprüngliche Nachricht-----
Von: mapguide-users-bounces at lists.osgeo.org
[mailto:mapguide-users-bounces at lists.osgeo.org] Im Auftrag von Jackie Ng
Gesendet: Freitag, 8. Juni 2007 08:17
An: mapguide-users at lists.osgeo.org
Betreff: Re: [mapguide-users] creating points at runtime / display problem
Hi Hans,
I had the same problem too, I submitted this problem ticket on Trac sometime
ago and has been fixed.
http://trac.osgeo.org/mapguide/ticket/53
The cause was the viewer sample.
- Jackie
Hans Mörschell wrote:
> Hallo,
> the problem I described can be seen also with the dotnetviewersample and
> the
> Sheboygan dataset. If you call the task findaddress and make a search the
> map is zooming to the right parcel but the blue push-pin marker is not
> shown. I think this might be the same problem.
> Is there anybody having the same issue, or is there may be some kind of
> bug
> in the Beta version (I didn't test it with MGOS 1.1) ?
> my configuration: MgOS 1.2 Beta2, IIS5, .NET development environment
> kind regards, Hans
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of
> G.E.O.-Consulting / Hans Morschell
> Sent: Wednesday, June 06, 2007 9:31 AM
> To: 'MapGuide Users Mail List'
> Subject: AW: AW: [mapguide-users] creating points at runtime / display
> problem/.NET
> Hallo,
> my problem is still the same: I can create a feature source, a layer and
> add
> the layer to the map during the session, add a point, the map is reacting
> to
> the maxscale for example, that means the XML file is ok, everything is
> shown
> in the legend, but in the map display the point is not shown ! The only
> thing I noticed is: in the access.log of the mapguide server there is a
> line
> like this:
MgOpGetIdentityProperties.1.0.0:3(MgResourceIdentifier,Default,startmarker)
> Failure
> where startmarker is my feature source. All other lines finish with
> success.
> Does that mean anything ?
> Thanks, Hans
>   _____
> mapguide-users mailing list
View this message in context:
http://www.nabble.com/creating-points-at-runtime---display-problem-tf3883395
s16610.html#a11021090
