[mapguide-users] creating points at runtime / display problem
Jackie Ng
jackie.ng at aecsystems.com.au
Fri Jun 8 02:17:18 EDT 2007
Hi Hans,
I had the same problem too, I submitted this problem ticket on Trac sometime
ago and has been fixed.
http://trac.osgeo.org/mapguide/ticket/53
The cause was the viewer sample.
- Jackie
Hans Mörschell wrote:
> Hallo,
> the problem I described can be seen also with the dotnetviewersample and
> the
> Sheboygan dataset. If you call the task findaddress and make a search the
> map is zooming to the right parcel but the blue push-pin marker is not
> shown. I think this might be the same problem.
> Is there anybody having the same issue, or is there may be some kind of
> bug
> in the Beta version (I didn't test it with MGOS 1.1) ?
> my configuration: MgOS 1.2 Beta2, IIS5, .NET development environment
> kind regards, Hans
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of
> G.E.O.-Consulting / Hans Morschell
> Sent: Wednesday, June 06, 2007 9:31 AM
> To: 'MapGuide Users Mail List'
> Subject: AW: AW: [mapguide-users] creating points at runtime / display
> problem/.NET
> Hallo,
> my problem is still the same: I can create a feature source, a layer and
> add
> the layer to the map during the session, add a point, the map is reacting
> to
> the maxscale for example, that means the XML file is ok, everything is
> shown
> in the legend, but in the map display the point is not shown ! The only
> thing I noticed is: in the access.log of the mapguide server there is a
> line
> like this:
> MgOpGetIdentityProperties.1.0.0:3(MgResourceIdentifier,Default,startmarker)
> Failure
> where startmarker is my feature source. All other lines finish with
> success.
> Does that mean anything ?
> Thanks, Hans
> _____
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
View this message in context: http://www.nabble.com/creating-points-at-runtime---display-problem-tf3883395s16610.html#a11021090
