[mapguide-users] OGR and MGOS
Kenneth, GEOGRAF A/S ks at geograf.dk
Fri Jun 8 07:09:56 EDT 2007
You must point to the folder, not the tab file.
You can then choose all the tab files as schemas.
Beware that it will break if there are "bad" (non MI) files in the folder.
Regards Kenneth, GEOGRAF A/S
martijni wrote:
> Kenneth,
> I downloaded your OGR, because the 3.2.1 and 3.2.2 version ain't working
> (3.2.2 beta is understandable since it's for MGOS 1.2, but 3.2.1 should be
> working, but shows no datasource and read only).
> After I tried yours it's shows the datasource and readonly, but when I try
> to make a connection it seems not possible as you can see on the
> screenshot....
> http://www.nabble.com/file/p11023030/ogr.jpg
> These is what I've added in the providers.xml
>         <FeatureProvider>
>             <Name>OSGeo.OGR.3.2</Name>
>             <DisplayName>FDO Provider for OGR</DisplayName>
>             <Description>Access to OGR data sources</Description>
>             <IsManaged>False</IsManaged>
>             <Version>3.2.2.0</Version>
>             <FeatureDataObjectsVersion>3.2.0.0</FeatureDataObjectsVersion>
> <LibraryPath>C:\ProgramFiles\MapGuideOpenSource\Server\Bin\FDO\OGRProvider.dll</LibraryPath>
>        </FeatureProvider>
> My intention is to get connection with mapinfo files.
> Any idea's in what I'm doing wrong?
> Thanks in advance.
> Kenneth, GEOGRAF A/S wrote:
>> I have built and posted providers for FDO 3.2 (MgOS 1.1) and FDO 3.1
>> (MgOS 1.0 and MgEP 1.0 + SP1).
>> The providers are built without Oracle support, using the latest OGR
>> provider code from Traian.
>> The manifest has been removed from these, hopefully fixing a few problems.
>> Download and use, is on your own risk. I provide no support for them.
>> http://www.hexad.dk/MapGuide/OGR Provider Release FDO 3.2 - Proj 4.5.0 -
>> GDal 1.3.2 - Geos 2.2.3 - No OCI.zip
>> http://www.hexad.dk/MapGuide/OGR Provider Release FDO 3.1 - Proj 4.5.0 -
>> Regards, Kenneth, GEOGRAF A/S
>> Traian Stanev wrote:
>>> The 3.2.2 build will not work with MapGuide 1.1, it is compiled for
>>> MapGuide 1.2. You need to try an older build of the DLL (3.2 perhaps?)
>>> or wait for MapGuide 1.2.
>>> There is another problem that may cause connection properties to not
>>> show up, which someone on this list traced to manifest issues in the
>>> dll. I hope to have a build of the dll without manifest (and with the
>>> fix for S57 files) posted some time soon. It will be a 3.2.2 build.
>>> In any case, I believe you have the first problem -- your OGR provider
>>> build is too new.
>>> Traian
>>>     -----Original Message-----
>>>     *From:* mapguide-users-bounces at lists.osgeo.org on behalf of Rahul
>>>     *Sent:* Tue 5/15/2007 6:52 AM
>>>     *To:* MapGuide Users Mail List
>>>     *Cc:*
>>>     *Subject:* RE: [mapguide-users] OGR and MGOS
>>>     Hi,
>>>              I tried to configure  OGR Provider 3.2.2_beta1 with
>>>     MapGuide Open Source 1.1.0 ,Finally when i tried to connect the
>>>     database using the OGR Provider(Using Map Guide Studio) I unable
>>>     to get the Connection Properties in the Editior,Like DataSource &
>>>     ReadOnly etc .Kindly refer to the screen shots.
>>>     Thks
>>>     Max
>>>     */Chris Gountanis <cgountanis at mpower-tech.com>/* wrote:
>>>         Using this download:
>>> http://download.osgeo.org/fdo/3.2.2-Beta1/OGRProvider-3.2.2_beta1.win32.zip
>>>         Put the OGRProvider.dll in C:\Program
>>>         Edited the C:\Program
>>>         Files\MapGuideOpenSource\Server\Bin\FDO\providers.xml
>>>         Added:
>>>           <FeatureProvider>
>>>             <Name>OSGeo.OGRProvider.3.2</Name>
>>>             <DisplayName>OSGeo FDO Provider for ArcSDE </DisplayName>
>>>             <Description>Read/write access to an ESRI ArcSDE-based
>>>         data store, using Oracle and SQL Server. </Description>
>>>             <Version>3.2.2_beta1</Version>
>>> <FeatureDataObjectsVersion>3.2.1.0</FeatureDataObjectsVersion>
>>>             <LibraryPath>OGRProvider.dll</LibraryPath>
>>>           </FeatureProvider>
>>>         I copied the FeatureProvider from above "ArcSDE". Once I
>>>         updated the DisplayName and Description to something like
>>>         <DisplayName>OSGeo FDO Provider for OGR </DisplayName> it
>>>         worked great J
>>>         Chris
>>>         ________________________________________
>>>         From: mapguide-users-bounces at lists.osgeo.org
>>>         [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of
>>>         Traian Stanev
>>>         Sent: Friday, May 11, 2007 1:59 PM
>>>         To: MapGuide Users Mail List
>>>         Subject: RE: [mapguide-users] OGR and MGOS
>>>         Edit providers.xml and then restart the server (I assume you
>>>         put the DLL in the /FDO/bin that belongs to the server). Then
>>>         it should show up in Studio. If it does not, check the dll
>>>         dependencies using depends or something...
>>>         As far as Write goes, it depends what you mean by write.
>>>         Insert, Update, Delete, Create Layer?
>>>         Traian
>>>         Chris Gountanis
>>>         Sent: Friday, May 11, 2007 2:48 PM
>>>         To: 'MapGuide Users Mail List'
>>>         OK I grabbed this version
>>>         what is the proper procedure. I edited the provider.xml file.
>>>         Same exact thing I did for Map 2008 and it worked.
>>>         Also is there a Read/Write solution to OGR?
>>>         Chris
>>>         Traian Stanev
>>>         Sent: Friday, May 11, 2007 1:41 PM
>>>         In Studio, create a New Data Connection. It will show a list
>>>         of providers including the OGR provider. When you press on
>>>         that, it will bring up a connection editor dialog that lets
>>>         you set the OGR connection string. If the provider does not
>>>         show up in the list, then it is not installed correctly on the
>>>         server.
>>>         Traian
>>>         Chris Gountanis
>>>         Sent: Friday, May 11, 2007 2:17 PM
>>>         Subject: [mapguide-users] OGR and MGOS
>>>         I have used the OGR in Map 2008 just fine. I want to know how
>>>         to use the OGR FDO in MapGuide OS. Studio won't show the data
>>>         type. Do you have to set the resource manually using the web
>>>         tier? If so what is an example of the XML?
>>>         Thanks!
>>>         Chris
>>>         _______________________________________________
>>>         mapguide-users mailing list
>>>         mapguide-users at lists.osgeo.org
>>>         http://lists.osgeo.org/mailman/listinfo/mapguide-users
>>>     You snooze, you lose. Get messages ASAP with AutoCheck
>>> <http://us.rd.yahoo.com/evt=47959/*http://advision.webevents.yahoo.com/mailbeta/newmail_html.html>
>>>     in the all-new Yahoo! Mail Beta.
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20070608/14442947/attachment.html
