[mapguide-users] SDF File Size(Maximum)
Kenneth, GEOGRAF A/S
ks at geograf.dk
Mon Jun 11 02:33:23 EDT 2007
Hmm... a bit hasty there... the new info shows this:
(10) Are there any known size limits to SQLite databases?
A database is limited in size to 2 tibibytes (2^41 bytes). That is a
theoretical limitation. In practice, you should try to keep your SQLite
databases below 100 gigabytes to avoid performance problems. If you need
to store 100 gigabytes or more in a database, consider using an
enterprise database engine which is designed for that purpose.
The theoretical limit on the number of rows in a table is 2^64-1,
though obviously you will run into the file size limitation prior to
reaching the row limit. A single row can hold up to 230 bytes of data in
the current implementation. The underlying file format supports row
sizes up to about 2^62 bytes.
There are probably limits on the number of tables or indices or the
number of columns in a table or index, but nobody is sure what those
limits are. In practice, SQLite must read and parse the original SQL of
all table and index declarations everytime a new database file is
opened, so for the best performance of sqlite3_open() it is best to keep
down the number of declared tables. Likewise, though there is no limit
on the number of columns in a table, more than a few hundred seems
extreme. Only the first 31 columns of a table are candidates for certain
optimizations. You can put as many columns in an index as you like but
indexes with more than 30 columns will not be used to optimize queries.
The names of tables, indices, view, triggers, and columns can be as
long as desired. However, the names of SQL functions (as created by the
sqlite3_create_function() API) may not exceed 255 characters in length.
So, it should in fact support 2 titibytes, providing that the file
system allows you to create files of that size (and you have enough
storage space).
Regards, Kenneth, GEOGRAF A/S
Kenneth, GEOGRAF A/S skrev:
> SDF is using the SQLite database for storage. The SQLite has the
> following size constraints:
> Internally, SQLite can handle databases up to 2^40 bytes (1
> terabyte) in size. But the backend interface to POSIX and Win32 limits
> files to 2^31 (2 gigabytes).
> SQLite arbitrarily limits the amount of data in one row to 1
> megabyte. There is a single #define in the source code that can be
> changed to raise this limit as high as 16 megabytes if desired.
> There is a theoretical limit of about 2^32 (4 billion) rows in a
> single table, but there is no way to test this limit without exceeding
> the maximum file size, so it is not really an issue. There is also a
> theoretical limit of about 2^32 tables and indices, but again it is
> not really possible to reach this limit due to the file size constraint.
> The name and "CREATE TABLE" statement for a table must fit
> entirely within a 1-megabyte row of the SQLITE_MASTER table. Other
> than this, there are no constraints on the length of the name of a
> table, or on the number of columns, etc. Indices are similarly
> unconstrained.
> So, if there are no bugs in the implementation, the size should be
> limited to 2 GB. You can read more about the SQLite format on:
> http://www.sqlite.org/
> Rahul skrev:
>> Hi All,
>> Can anyone tell me that how much the maximum SDF File
>> size(single) supported by Autodesk(ADSKServer,Map3D 2008).Any
>> reference or detail link will be really helpfull for me.
>> ESRI use to provide support for max. 4 GB personal geodatabase File.
>> Thks
>> Max
>> It's here! Your new message!
>> Get new email alerts
>> <http://us.rd.yahoo.com/evt=49938/*http://tools.search.yahoo.com/toolbar/features/mail/>
>> with the free Yahoo! Toolbar.
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20070611/bef37cf0/attachment.html
