[mapguide-users] Desktop implementation of MapGuide
Jackie Ng jackie.ng at aecsystems.com.au
Mon Jun 11 16:28:02 EDT 2007
What dll(s) would I need to reference for the dwfviewer api?
Regards,
- Jackie
alucas wrote:
> Hello,
> It's is possible, I've implemented a viewer in c# based on DWF Viewer, it
> works fine in the LAN but I've some problems connecting vía internet.
> You need:
> Include your webconfig.ini -> When your app start, you need to read the
> ipaddress and if the user can specify the server, you need to write the
> webconfig.ini with this ip, because the api (InitializeWebTier) reads this
> file.
> You need to add a reference to dwfviewer api
> You need to add a referende to mapguidedotnetapi.dll
> Include all dll's in the API in the .exe directory. You can get this
> dependent files from c:\Program files\mapguideopensource\server\bin
> You need the resources file, in the webconfig.ini the parameter
> ResourcesPath points to the resources file.
> Now, you need to connect to the mapagent and generate a dwf map with the
> mapping service, then, you can store it in the client and open it with
> dwfviewer.
> You don't need to implement the navigation and display tools.
> This works fine for the LAN, I can acces to all mapguide servers in my
> LAN. Through internet I'm having problems...
> Kneo wrote:
>> Would it be possible to have a desktop implementation of MapGuide
>> (offline viewing) ? Basically, the desktop application created in VB.net
>> will connect to a set of servers to fetch the map and then allow the user
>> to browse it offline. Since the map is now copied to the local desktop,
>> the speed and flexibility will be immense.
View this message in context: http://www.nabble.com/Desktop-implementation-of-MapGuide-tf3900680s16610.html#a11068130
