AW: [mapguide-users] Bad Performance using dwf Files
Stephan HOLLAUS stephan.hollaus at hollaus.at
Tue Jun 12 04:59:56 EDT 2007
No. I have only one Layer for Visualization(1 dwf).
I played around and when I drop all the hatches in the dwf it runs much faster. Is there a known problem with hatches and dwf?
mfg Stephan Hollaus
Ingenieur Studio Hollaus
Tel.:   +43 664 3387158
Fax.:  +43 664 77 3387159
www: http://www.hollaus.at
Brandströmgasse 10
3100 St. Pölten
V55BCPWP
-----Ursprüngliche Nachricht-----
Von: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] Im Auftrag von Maciej Skorczewski
Gesendet: Dienstag, 12. Juni 2007 10:55
An: MapGuide Users Mail List
Betreff: Re: [mapguide-users] Bad Performance using dwf Files
Hi Stephan!
Did you try Tile Base in Ajax Viewer?.
try use scale to show/hide some layer....
In my aplication i saw that if i show only shapes like (polygon, line)
whit 3-4 layer in Tile Base it is fast...but when yu put label (street
name etc) it generate bigger PNG so it is bit slower.
...still wainting for speed like in maps.google.com :)
...MG 1.3 ?
Stephan Hollaus pisze:
> I'm using dwf Files as drawing source, and the view is ok. But the
> Performance is very bad(~30sec after every Pan/Zoom)
> The dwf File is about 10MB. Is there a possibillity to generate an index for
> the dwf to make it faster? What else could i use?
> mfg
mapguide-users mailing list
mapguide-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-users
