[mapguide-users] MapGuide 1.1.0 On Red Hat EL 4
Audaire David DAUDAIRE at ares.fr
Wed Jun 13 12:18:41 EDT 2007
Why don't you install the recomanded GCC and compile mapguide with it with an
export CC=/path to gcc dir you want to use
before doing the build.
i have to do that
James Card wrote:
> We've got a client who wants to run only non-beta software -- which means
> MapGuide OS 1.1.0 rather than 1.2.0 (because they want delivery before the
> end of June) -- on their Red Hat Enterprise Linux ES 4 Update 4 server.
> The install proceeds well until we come to build_oem.sh, which aborts
> after encountering ACE errors. I understand that this is likely a
> compatibility issue between the GCC 3.4.6 installed by Red Hat, and the
> GCC 3.2.3 used for MapGuide 1.1.0. I also hear that thre are
> "compatibility libraries" available that might resolve this problem.
> Can someone point me to a step-by-step guide (I'm not very Linux-friendly
> yet) to how we might install and use those libraries? Is there some other
> way to resolve this problem?
> James Card
> 209-578-5580
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
View this message in context: http://www.nabble.com/MapGuide-1.1.0-On-Red-Hat-EL-4-tf3915702s16610.html#a11103095
