[mapguide-users] Newbie Web Studio question
usysinc info at usysinc.com
Wed Jun 13 13:10:56 EDT 2007
Hi, I'm also new to this project using 1.1.0 and have experienced the
WebStudio Error as described below:
Line: 285
Char: 13
Error: 'this.resources[...].getView()' is null or not an object
I however have not even been able to get ANY of the examples to work!!
Compiling a small Java applet such as "HelloWorld" and placing the .class
file in the
C:\Program
Files\MapGuideOpenSource\WebServerExtensions\Tomcat\webapps\ROOT\WEB-INF\classes
directory however works just fine.
I suppose that I have more than one config. problem. Any thoughts on these
issues?
Regards,
  Brendan
Jorge Rubio wrote:
> Do you have "Error on page" bottom left? if you double click and then show
> details do you have
> Line: 285
> Char: 13
> message?
> 2007/3/13, Angela Moore <amoore at franklinnc.com>:
>> Thanks for the reply,
>> Yes, I did log in as you stated below, but I do not see anything in the
>> site explorer.  It is empty.  I have installed the sample data and the
>> sheboygan package.  The demo runs with no problems, but I see nothing in
>> the explorer window.  Has anyone else experienced this problem?  Thanks
>> Angela
>> Jorge Rubio wrote:
>> > Did you logged as
>> > Administrator
>> > admin
>> > at http://localhost/mapguide (windows) or
>> > http://locahost:8080/mapguide (linux)?
>> > You should see in the Site Explorer Panel what you have at your
>> Library.
>> > Did you installed some sample data? Maybe you should try dowloading
>> > some pgp files from osgeo.mapguide site.
>> > On the other hand, Web Studio does not has same functionality than
>> > MapGuideStudio. For example, you can´t create Web Layouts.
>> > <mailto:amoore at franklinnc.com>>:
>> >     I'm probably missing something simple here, or maybe looking for
>> >     something that isn't available yet, but I can't find an answer so
>> >     here
>> >     goes with a newbie question.  I've installed mapguide open source
>> with
>> >     the default apache php installation.  The examples all run without
>> a
>> >     hitch.  After much searching I found MapGuide Open Source Web
>> Studio
>> >     hidden at C:\Program
>> >     Files\MapGuideOpenSource\WebserverExtensions\www\webstudio  I
>> >     opened it
>> >     using the launch file and the index.  Regardless of if I log in as
>> >     administrator or author I find that I can't do anything but look
>> >     at the
>> >     help menus and the site administrator.  I can't get anything to
>> >     show up
>> >     in the site explorer.  I have tried creating a new feature source,
>> but
>> >     when I try nothing happens.  Is Web Studio simply not developed
>> >     beyond
>> >     this point, or am I missing something.  I would appreciate any help
>> on
>> >     this issue.
>> >     Thanks
>> >     Angela Moore
>> >     _______________________________________________
>> >     mapguide-users mailing list
>> >     mapguide-users at lists.osgeo.org <mailto:
>> mapguide-users at lists.osgeo.org>
>> >     http://lists.osgeo.org/mailman/listinfo/mapguide-users
>> > Lic. Jorge Rubio
> Lic. Jorge Rubio
View this message in context: http://www.nabble.com/Newbie-Web-Studio-question-tf3398264s16610.html#a11104149
