[mapguide-users] OGR / GEOS selection problem
Traian Stanev traian.stanev at autodesk.com
Wed Jun 13 15:24:59 EDT 2007
To put test data into PostGres I use the tool that comes with it that
can import SHP files into the database.
I think it's called shp2pgsql.
Traian
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Kenneth,
GEOGRAF A/S
Sent: Wednesday, June 13, 2007 3:21 PM
To: MapGuide Users Mail List
Subject: Re: [mapguide-users] OGR / GEOS selection problem
I tried it with MapInfo TAB files, and it works fine.
Maciej, can you post an SQL dump of one of the PostGIS tables?
I have installed PostGIS on my machine for testing, but I have no data,
and no luck getting Fdo2Fdo working with FDO OGR.
Regards, Kenneth, GEOGRAF A/S
Traian Stanev skrev:
> Well, I only tried it with SHP files and am pretty sure it fixed the
> problem for SHP files (I did a before and after test, on a polygon
that
> had the same problem as your screenshot). May be the PostGIS OGR
driver
> does something else, like forward the spatial filter to PostGIS? In
that
> case, may be I need to upgrade my PostGIS SDK...? Anybody know the
> answer to that one?
> Traian
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Maciej
> Skorczewski
> Sent: Wednesday, June 13, 2007 12:29 PM
> Traian
> i have still this same error...
> take a look on screen.
> http://imagepolis.com/images/20070613819095046.JPG
> http://imagepolis.com/images/20070613818181055.JPG
> http://imagepolis.com/images/20070613434408347.JPG
> Maciek
> ps. and i still can't use SetSelectionXML...
http://www.nabble.com/SetSelectionXML-on-layer-from-database-%28PostgreS
> QL-%3EPostgGIS%29-tf3900386s16610.html
> (tiny of this url to forum)
> http://tiny.pl/fdtn
> maciek skorczewski
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
