[mapguide-users] OGR / GEOS selection problem
Kenneth, GEOGRAF A/S
ks at geograf.dk
Wed Jun 13 17:42:43 EDT 2007
It is actually forwarded to PostGIS:
OGREnvelope sEnvelope;
m_poFilterGeom->getEnvelope( &sEnvelope );
osWHERE.Printf("WHERE %s && SetSRID('BOX3D(%.12f %.12f, %.12f
%.12f)'::box3d,%d) ",
pszGeomColumn,
sEnvelope.MinX, sEnvelope.MinY,
sEnvelope.MaxX, sEnvelope.MaxY,
nSRSId );
Not too good with PostGIS syntax, but since the m_poFilterGeom is the
filter used (a small square in this case) it reads:
"Select from geometry_column where features are within the bbox of the
filer"
Which should be quite ok, unless they have a similar idea of optimizing
this to a BBOX test, as OGR does.
Anyway, I can confirm that Traians fix works with MapInfo TAB files, but
NOT with PostGIS :(
Regards, Kenneth, GEOGRAF A/S
Traian Stanev skrev:
> To put test data into PostGres I use the tool that comes with it that
> can import SHP files into the database.
> I think it's called shp2pgsql.
> Traian
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Kenneth,
> GEOGRAF A/S
> Sent: Wednesday, June 13, 2007 3:21 PM
> To: MapGuide Users Mail List
> Subject: Re: [mapguide-users] OGR / GEOS selection problem
> I tried it with MapInfo TAB files, and it works fine.
> Maciej, can you post an SQL dump of one of the PostGIS tables?
> I have installed PostGIS on my machine for testing, but I have no data,
> and no luck getting Fdo2Fdo working with FDO OGR.
>> Well, I only tried it with SHP files and am pretty sure it fixed the
>> problem for SHP files (I did a before and after test, on a polygon
> that
>> had the same problem as your screenshot). May be the PostGIS OGR
> driver
>> does something else, like forward the spatial filter to PostGIS? In
> that
>> case, may be I need to upgrade my PostGIS SDK...? Anybody know the
>> answer to that one?
>> Traian
>> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Maciej
>> Skorczewski
>> Sent: Wednesday, June 13, 2007 12:29 PM
>> Traian
>> i have still this same error...
>> take a look on screen.
>> http://imagepolis.com/images/20070613819095046.JPG
>> http://imagepolis.com/images/20070613818181055.JPG
>> http://imagepolis.com/images/20070613434408347.JPG
>> Maciek
>> ps. and i still can't use SetSelectionXML...
> http://www.nabble.com/SetSelectionXML-on-layer-from-database-%28PostgreS
>> QL-%3EPostgGIS%29-tf3900386s16610.html
>> (tiny of this url to forum)
>> http://tiny.pl/fdtn
>> maciek skorczewski
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20070613/ad4a309a/attachment.html
