[mapguide-users] OGR / GEOS selection problem
Traian Stanev
traian.stanev at autodesk.com
Wed Jun 13 19:48:39 EDT 2007
Wait, from this it looks like it takes the BBOX (envelope) of the filter and sends that to PostGIS...? That may explain things.
-----Original Message-----
From: mapguide-users-bounces at lists.osgeo.org on behalf of Kenneth, GEOGRAF A/S
Sent: Wed 6/13/2007 5:42 PM
To: MapGuide Users Mail List
Cc:
Subject: Re: [mapguide-users] OGR / GEOS selection problem
It is actually forwarded to PostGIS:
OGREnvelope sEnvelope;
m_poFilterGeom->getEnvelope( &sEnvelope );
osWHERE.Printf("WHERE %s && SetSRID('BOX3D(%.12f %.12f, %.12f %.12f)'::box3d,%d) ",
pszGeomColumn,
sEnvelope.MinX, sEnvelope.MinY,
sEnvelope.MaxX, sEnvelope.MaxY,
nSRSId );
Not too good with PostGIS syntax, but since the m_poFilterGeom is the filter used (a small square in this case) it reads:
"Select from geometry_column where features are within the bbox of the filer"
Which should be quite ok, unless they have a similar idea of optimizing this to a BBOX test, as OGR does.
Anyway, I can confirm that Traians fix works with MapInfo TAB files, but NOT with PostGIS :(
Regards, Kenneth, GEOGRAF A/S
Traian Stanev skrev:
To put test data into PostGres I use the tool that comes with it that
can import SHP files into the database.
I think it's called shp2pgsql.
Traian
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Kenneth,
GEOGRAF A/S
Sent: Wednesday, June 13, 2007 3:21 PM
I tried it with MapInfo TAB files, and it works fine.
Maciej, can you post an SQL dump of one of the PostGIS tables?
I have installed PostGIS on my machine for testing, but I have no data,
and no luck getting Fdo2Fdo working with FDO OGR.
Well, I only tried it with SHP files and am pretty sure it fixed the
problem for SHP files (I did a before and after test, on a polygon
that
had the same problem as your screenshot). May be the PostGIS OGR
driver
does something else, like forward the spatial filter to PostGIS? In
that
case, may be I need to upgrade my PostGIS SDK...? Anybody know the
answer to that one?
Traian
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Maciej
Skorczewski
Sent: Wednesday, June 13, 2007 12:29 PM
Traian
i have still this same error...
take a look on screen.
http://imagepolis.com/images/20070613819095046.JPG
http://imagepolis.com/images/20070613818181055.JPG
http://imagepolis.com/images/20070613434408347.JPG
Maciek
ps. and i still can't use SetSelectionXML...
http://www.nabble.com/SetSelectionXML-on-layer-from-database-%28PostgreS
QL-%3EPostgGIS%29-tf3900386s16610.html
(tiny of this url to forum)
http://tiny.pl/fdtn
maciek skorczewski
mapguide-users mailing list
mapguide-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20070613/5688d922/attachment.html
