[mapguide-users] OGR / GEOS selection problem
Kenneth, GEOGRAF A/S
ks at geograf.dk
Thu Jun 14 04:14:39 EDT 2007
It should not work if you make a polygon selection.
Tooltip and Click sends a square, so the envelope of the filter should
be the same as the filter
Regards, Kenneth, GEOGRAF A/S
Traian Stanev skrev:
> Wait, from this it looks like it takes the BBOX (envelope) of the
> filter and sends that to PostGIS...? That may explain things.
> -----Original Message-----
> *From:* mapguide-users-bounces at lists.osgeo.org on behalf
> of Kenneth, GEOGRAF A/S
> *Sent:* Wed 6/13/2007 5:42 PM
> *To:* MapGuide Users Mail List
> *Cc:*
> *Subject:* Re: [mapguide-users] OGR / GEOS selection problem
> It is actually forwarded to PostGIS:
> OGREnvelope sEnvelope;
> m_poFilterGeom->getEnvelope( &sEnvelope );
> osWHERE.Printf("WHERE %s && SetSRID('BOX3D(%.12f %.12f,
> %.12f %.12f)'::box3d,%d) ",
> pszGeomColumn,
> sEnvelope.MinX, sEnvelope.MinY,
> sEnvelope.MaxX, sEnvelope.MaxY,
> nSRSId );
> Not too good with PostGIS syntax, but since the m_poFilterGeom is
> the filter used (a small square in this case) it reads:
> "Select from geometry_column where features are within the bbox of
> the filer"
> Which should be quite ok, unless they have a similar idea of
> optimizing this to a BBOX test, as OGR does.
> Anyway, I can confirm that Traians fix works with MapInfo TAB
> files, but NOT with PostGIS :(
>> To put test data into PostGres I use the tool that comes with it that
>> can import SHP files into the database.
>> I think it's called shp2pgsql.
>> Traian
>> From: mapguide-users-bounces at lists.osgeo.org
>> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Kenneth,
>> GEOGRAF A/S
>> Sent: Wednesday, June 13, 2007 3:21 PM
>> To: MapGuide Users Mail List
>> Subject: Re: [mapguide-users] OGR / GEOS selection problem
>> I tried it with MapInfo TAB files, and it works fine.
>> Maciej, can you post an SQL dump of one of the PostGIS tables?
>> I have installed PostGIS on my machine for testing, but I have no data,
>> and no luck getting Fdo2Fdo working with FDO OGR.
>>> Well, I only tried it with SHP files and am pretty sure it fixed the
>>> problem for SHP files (I did a before and after test, on a polygon
>> that
>>> had the same problem as your screenshot). May be the PostGIS OGR
>> driver
>>> does something else, like forward the spatial filter to PostGIS? In
>> that
>>> case, may be I need to upgrade my PostGIS SDK...? Anybody know the
>>> answer to that one?
>>> Traian
>>> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Maciej
>>> Skorczewski
>>> Sent: Wednesday, June 13, 2007 12:29 PM
>>> Traian
>>> i have still this same error...
>>> take a look on screen.
>>> http://imagepolis.com/images/20070613819095046.JPG
>>> http://imagepolis.com/images/20070613818181055.JPG
>>> http://imagepolis.com/images/20070613434408347.JPG
>>> Maciek
>>> ps. and i still can't use SetSelectionXML...
>> http://www.nabble.com/SetSelectionXML-on-layer-from-database-%28PostgreS
>>> QL-%3EPostgGIS%29-tf3900386s16610.html
>>> (tiny of this url to forum)
>>> http://tiny.pl/fdtn
>>> maciek skorczewski
>>> mapguide-users mailing list
>>> mapguide-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20070614/8ac0c9c1/attachment.html
