[mapguide-users] RE: Raster Support
ori gudes
origu at omnitech.co.il
Thu Jun 14 10:52:30 EDT 2007
Andy, Richard and Frank
Thanks very much, I did what Frank recommended and it works perfect for (ECW
and TIFF) however, I still can't see Mr' SID format, any suggestions ? As
for the others, I did some screen shot document (Attached here) that
simplifies the all process, this mite help for other people as well And save
their time !
Regards Ori
RichBauer wrote:
> Ori,
> It sounds like I had a similar problem, actually sound like I had
> exactly the same problem. The forum post is here:
> http://www.nabble.com/SID-Raster-Problem-tf3853167s16610.html#a10918776
> For 1.1.0, Frank had a fix that worked perfect. Try that fix and
> see.
> Rich
> ori gudes wrote:
> Dear Andy
> I did all the process mentioned at the "Using fdogdal in Autodesk MapGuide
> Studio" However, maybe I don't understand basic think here !? After I
> define
> the
> DefaultRasterFileLocation property, I create a layer that point to this
> resource and expecting to see this raster as a layer in the preview, then
> to add this layer to the Map definitions.
> Maybe you can add 2 screen shots so I can understand what I am doing wrong
> here?
> Regards Ori
> Andy Morsell wrote:
> Ori,
> Not sure if you saw my reply to your PM this morning regarding this topic:
> Ori,
> See this page for more information:
> http://wiki.osgeo.org/index.php/MapGuide_Open_Source_Using_the_Open_Source_R
> aster_Provider_with_Studio
> Andy Morsell, P.E.
> Spatial Integrators, Inc.
> http://www.SpatialGIS.com
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org
> [ mailto:mapguide-users-bounces at lists.osgeo.org ] On Behalf Of ori gudes
> Sent: Wednesday, June 13, 2007 5:51 AM
> To: mapguide-users at lists.osgeo.org
> Subject: [mapguide-users] Raster Support
> Hi All
> I have few versions of MapGuide Open Source (1.02, 1.1) I noticed that
> the
> raster support is very problematic issue.
> 1) Does version 1.2 supports all raters files ?
> 2) After I define a connection to a raster in version 1.1, I should create
> a
> layer that point to the raster feature source, however I don't see any
> preview after all this process has completed ?
> 3) Any document that summarize this issue once for all ? I saw many
> queries
> in the forum, but couldn't get any organized summary !
> Thanks in advance Ori
> http://www.nabble.com/Raster-Support-tf3914471s16610.html#a11098764
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
http://www.nabble.com/file/p11121506/how%2Bto%2Bupload%2BRaster%2Bin%2Bto%2BMapguide%2BOpen%2BSource.doc
how+to+upload+Raster+in+to+Mapguide+Open+Source.doc
View this message in context: http://www.nabble.com/Raster-Support-tf3914471s16610.html#a11121506
