[mapguide-users] RE: Raster Support
ori gudes origu at omnitech.co.il
Thu Jun 14 11:18:00 EDT 2007
You can download the documantation file (how to upload raster) at this link:
http://www.sinapistech.com/images/stories/temp_ori/Raster.doc
Regards Ori
ori gudes wrote:
> Andy, Richard and Frank
> Thanks very much, I did what Frank recommended and it works perfect for
> (ECW and TIFF) however, I still can't see Mr' SID format, any suggestions
> ? As for the others, I did some screen shot document (Attached here) that
> simplifies the all process, this mite help for other people as well And
> save their time !
> Regards Ori
> RichBauer wrote:
>> Ori,
>> It sounds like I had a similar problem, actually sound like I had
>> exactly the same problem.  The forum post is here:
>> http://www.nabble.com/SID-Raster-Problem-tf3853167s16610.html#a10918776
>> For 1.1.0, Frank had a fix that worked perfect.  Try that fix and
>> see.
>> Rich
>> ori gudes wrote:
>>   Dear Andy
>> I did all the process mentioned at the "Using fdogdal in Autodesk
>> MapGuide
>> Studio" However, maybe I don't understand basic think here !? After I
>> define
>> the
>> DefaultRasterFileLocation property, I create a layer that point to this
>> resource and expecting to see this raster as a layer in the preview,
>> then
>> to add this layer to the Map definitions.
>> Maybe you can add 2 screen shots so I can understand what I am doing
>> wrong
>> here?
>> Regards Ori
>> Andy Morsell wrote:
>>     Ori,
>> Not sure if you saw my reply to your PM this morning regarding this
>> topic:
>> Ori,
>> See this page for more information:
>> http://wiki.osgeo.org/index.php/MapGuide_Open_Source_Using_the_Open_Source_R
>> aster_Provider_with_Studio
>> Andy Morsell, P.E.
>> Spatial Integrators, Inc.
>> http://www.SpatialGIS.com
>> -----Original Message-----
>> From: mapguide-users-bounces at lists.osgeo.org
>> [ mailto:mapguide-users-bounces at lists.osgeo.org ] On Behalf Of ori gudes
>> Sent: Wednesday, June 13, 2007 5:51 AM
>> To: mapguide-users at lists.osgeo.org
>> Subject: [mapguide-users] Raster Support
>> Hi All
>> I have few versions of  MapGuide Open Source (1.02, 1.1) I noticed that
>> the
>> raster support is very  problematic issue.
>> 1) Does version 1.2 supports all raters files ?
>> 2) After I define a connection to a raster in version 1.1, I should
>> create
>> a
>> layer that point to the raster feature source, however I don't see any
>> preview after all this process has completed ?
>> 3) Any document that summarize this issue once for all ? I saw many
>> queries
>> in the forum, but couldn't get any organized summary !
>> Thanks in advance Ori
>> View this message in context:
>> http://www.nabble.com/Raster-Support-tf3914471s16610.html#a11098764
>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>> mapguide-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
> http://www.nabble.com/file/p11121506/how%2Bto%2Bupload%2BRaster%2Bin%2Bto%2BMapguide%2BOpen%2BSource.doc
> how+to+upload+Raster+in+to+Mapguide+Open+Source.doc
View this message in context: http://www.nabble.com/Raster-Support-tf3914471s16610.html#a11121531
