[mapguide-users] RE: Raster Support
Andy Morsell
amorsell at spatialgis.com
Thu Jun 14 10:42:31 EDT 2007
Ori,
Sounds like you have not yet created the map, see this section of that
document:
"The layer definition preview will not show the raster. In order to preview
the data, create a map definition and set the extents of the map to contain
the raster data. If the extents are set correctly the raster data should
show in the preview."
Andy
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of ori gudes
Sent: Thursday, June 14, 2007 3:12 AM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] RE: Raster Support
Dear Andy
I did all the process mentioned at the "Using fdogdal in Autodesk MapGuide
Studio" However, maybe I don't understand basic think here !? After I define
the DefaultRasterFileLocation property, I create a layer that point to this
resource and expecting to see this raster as a layer in the preview, then
to add this layer to the Map definitions.
Maybe you can add 2 screen shots so I can understand what I am doing wrong
here?
Regards Ori
Andy Morsell wrote:
> Ori,
> Not sure if you saw my reply to your PM this morning regarding this topic:
> Ori,
> See this page for more information:
> http://wiki.osgeo.org/index.php/MapGuide_Open_Source_Using_the_Open_So
> urce_R
> aster_Provider_with_Studio
> Andy Morsell, P.E.
> Spatial Integrators, Inc.
> http://www.SpatialGIS.com
> From: mapguide-users-bounces at lists.osgeo.org
> Sent: Wednesday, June 13, 2007 5:51 AM
> Subject: [mapguide-users] Raster Support
> Hi All
> I have few versions of MapGuide Open Source (1.02, 1.1) I noticed
> that the raster support is very problematic issue.
> 1) Does version 1.2 supports all raters files ?
> 2) After I define a connection to a raster in version 1.1, I should
> create a layer that point to the raster feature source, however I
> don't see any preview after all this process has completed ?
> 3) Any document that summarize this issue once for all ? I saw many
> queries in the forum, but couldn't get any organized summary !
> Thanks in advance Ori
> http://www.nabble.com/Raster-Support-tf3914471s16610.html#a11098764
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
http://www.nabble.com/Raster-Support-tf3914471s16610.html#a11117346
