[mapguide-users] RE: Raster Support
ori gudes origu at omnitech.co.il
Thu Jun 14 12:01:34 EDT 2007
Hi Frank
 I defined a map and succeed to upload and to see ECW file and also Tiff in
the map and also in the layers previews. The only problem now, is to to
watch Mr' SID format
Cheers Ori
Regards Ori
Frank Warmerdam-2 wrote:
> Andy Morsell wrote:
>> Ori,
>> Sounds like you have not yet created the map, see this section of that
>> document:
>> "The layer definition preview will not show the raster. In order to
>> preview
>> the data, create a map definition and set the extents of the map to
>> contain
>> the raster data. If the extents are set correctly the raster data should
>> show in the preview."
> Andy,
> But that problem was supposed to have been resolved by later changes of
> mine. I'm not exactly sure if that made it into the latest 1.1 binaries
> I posted or not.
> BTW, I've moved the various wiki notes on the fdogdal provider to:
>    http://trac.osgeo.org/fdo/wiki/FdoGdalNotes
> Anyone with an osgeo userid should be able to login and improve it.
> Best regards,
> I set the clouds in motion - turn up   | Frank Warmerdam,
> warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush    | President OSGeo, http://osgeo.org
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
View this message in context: http://www.nabble.com/Raster-Support-tf3914471s16610.html#a11123188
