[mapguide-users] Problems with data external join
Mbonnet mbonnet at adelior.gfi.fr
Fri Jun 15 03:59:55 EDT 2007
Hi all,
I have created a feature source from a SDF file, and i have join datas from
a oracle database with ODBC FDO driver. I'm using mapguide opensource 1.2
beta with mapguide studio 2007. When i select a feature on the map all the
datas appears in the properties panel. But when i want to show a label on
the feature, for exemple their ID, the data is incorrect. For example : the
room number 12 (data in the properties panel), the label which shows the id
is : 14, i have the same problem with filter.
Is it a known problem ???
please Help me.
View this message in context: http://www.nabble.com/Problems-with-data-external-join-tf3926360s16610.html#a11134869
