[mapguide-users] Problems with data external join
Jason Birch Jason.Birch at nanaimo.ca
Fri Jun 15 11:06:05 EDT 2007
Yes, it's a known issue:
http://trac.osgeo.org/mapguide/ticket/146
http://trac.osgeo.org/mapguide/changeset/1749
http://trac.osgeo.org/mapguide/changeset/1750
Please try with RC1.
Jason
-----Original Message-----
Subject: [mapguide-users] Problems with data external join
I have created a feature source from a SDF file, and i have join datas
from a oracle database with ODBC FDO driver. I'm using mapguide
opensource 1.2 beta with mapguide studio 2007. When i select a feature
on the map all the datas appears in the properties panel. But when i
want to show a label on the feature, for exemple their ID, the data is
incorrect. For example : the room number 12 (data in the properties
panel), the label which shows the id is : 14, i have the same problem
with filter.
Is it a known problem ???
