[mapguide-users] MapGuide & Map3D 2007 Publish Failure
Eric Blush
eblush at schererville.org
Fri Jun 15 14:39:02 EDT 2007
Applying the patch defiantly fixed my problem but after doing so I
started experiencing some weird behavior. Every time I try to switch to
3D view, Autodesk Map3d 2007 crashes. Has anyone else experienced this
problem or is this perhaps unrelated to changing that .dll file? Thanks
--Eric
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Chris
Gountanis
Sent: Tuesday, June 12, 2007 10:27 AM
To: 'MapGuide Users Mail List'
Subject: RE: [mapguide-users] MapGuide & Map3D 2007 Publish Failure
You need to replace the dll within the Map 2007 folder, same as Studio
when using a newer release of MapGuide Open Source.
http://download.osgeo.org/mapguide/patches/mapguidestudio/1.2.0/Autodesk
.MapGuide.Studio.Site.zip
Chris
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Eric Blush
Sent: Tuesday, June 12, 2007 10:11 AM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] MapGuide & Map3D 2007 Publish Failure
Hello all,
I am new to this and am attempting to publish to MapGuide from Autodesk
Map 3D 2007 and every time I attempt to connect in map it gives me a
very basic error to the effect of Connection Failed. I have attempted
to use every combination of MapGuide Open Source 1.1.x and MGOS 1.2.0 on
a Win2000 Server and Win2003 Server Standard Ed and have had no luck
with any of them. I am now convinced that it is an issue with the way I
have MapGuide set up. I know that the information I've given doesn't
seem very descriptive but it's all I have at the point. Does anyone
have any idea what I might be doing wrong? Thanks a lot.
--Eric
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20070615/855a7c02/attachment.html
