[mapguide-users] MapGuide & Map3D 2007 Publish Failure
Chris Gountanis cgountanis at mpower-tech.com
Fri Jun 15 15:34:55 EDT 2007
I have not seen that issue with my 2007. I think the only thing that uses
that dll is the publish to mapguide but I could be wrong. Did you have this
problem before and what happens when you revert to the original DLL? With
all that you should have your answers.
Chris
  _____
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Eric Blush
Sent: Friday, June 15, 2007 1:39 PM
To: MapGuide Users Mail List
Subject: RE: [mapguide-users] MapGuide & Map3D 2007 Publish Failure
Applying the patch defiantly fixed my problem but after doing so I started
experiencing some weird behavior.  Every time I try to switch to 3D view,
Autodesk Map3d 2007 crashes.  Has anyone else experienced this problem or is
this perhaps unrelated to changing that .dll file? Thanks
--Eric
  _____
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Chris Gountanis
Sent: Tuesday, June 12, 2007 10:27 AM
To: 'MapGuide Users Mail List'
You need to replace the dll within the Map 2007 folder, same as Studio when
using a newer release of MapGuide Open Source.
http://download.osgeo.org/mapguide/patches/mapguidestudio/1.2.0/Autodesk.Map
Guide.Studio.Site.zip
Chris
  _____
Sent: Tuesday, June 12, 2007 10:11 AM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] MapGuide & Map3D 2007 Publish Failure
Hello all,
I am new to this and am attempting to publish to MapGuide from Autodesk Map
3D 2007 and every time I attempt to connect in map it gives me a very basic
error to the effect of Connection Failed.  I have attempted to use every
combination of MapGuide Open Source 1.1.x and MGOS 1.2.0 on a Win2000 Server
and Win2003 Server Standard Ed and have had no luck with any of them.  I am
now convinced that it is an issue with the way I have MapGuide set up.  I
know that the information I've given doesn't seem very descriptive but it's
all I have at the point.  Does anyone have any idea what I might be doing
wrong?  Thanks a lot.
--Eric
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20070615/24d66c0b/attachment.html
