[mapguide-users] MapGuide & Map3D 2007 Publish Failure
Francisco Javier Rojas Durán
francisco.rojas at dasoft.com.mx
Sat Jun 16 08:37:53 EDT 2007
Hi:
You must know also that MGOS 1.0.x has the same FDO version and
compatibility for Adsk Map & MapGuide Ent 2007 Platform, so it's not
compatible with MGOS 1.1.x and 1.2.x, for solve this issue you can either
install the Autodesk.MapGuide.Studio.Site.zip or Use MapGuide Studio 2008
Beta Version which it is shipped now with MapGuide Ent 2008 Beta Version and
Topobase 2008 Beta 3, if you dont have access to this beta programs you can
wait until July 5th when MapGuide Enterprise 2008 will be launched by
Autodesk.
I want to point out that MGOS 1.2.x has the same technology and FDO Platform
version as in AutoCAD Map 3D 2008 and MapGuide Enterprise 2008.
Regards
Francisco Rojas
Grupo DaSoft
Autodesk Developer Network Member
Date: Tue, 12 Jun 2007 11:58:18 -0500
Subject: RE: [mapguide-users] MapGuide & Map3D 2007 Publish Failure
To: "MapGuide Users Mail List" <mapguide-users at lists.osgeo.org>
Message-ID:
<5A6A0D61E98C3D45989C8279656BFF1739DC0F at TOSNET.schererville.local>
Content-Type: text/plain; charset="us-ascii"
Thanks, I'll try that and see if it resolves this.
--Eric
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Chris
Gountanis
Sent: Tuesday, June 12, 2007 10:27 AM
To: 'MapGuide Users Mail List'
You need to replace the dll within the Map 2007 folder, same as Studio
when using a newer release of MapGuide Open Source.
http://download.osgeo.org/mapguide/patches/mapguidestudio/1.2.0/Autodesk
Chris
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Eric Blush
Sent: Tuesday, June 12, 2007 10:11 AM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] MapGuide & Map3D 2007 Publish Failure
Hello all,
I am new to this and am attempting to publish to MapGuide from Autodesk
Map 3D 2007 and every time I attempt to connect in map it gives me a
very basic error to the effect of Connection Failed. I have attempted
to use every combination of MapGuide Open Source 1.1.x and MGOS 1.2.0 on
a Win2000 Server and Win2003 Server Standard Ed and have had no luck
with any of them. I am now convinced that it is an issue with the way I
have MapGuide set up. I know that the information I've given doesn't
seem very descriptive but it's all I have at the point. Does anyone
have any idea what I might be doing wrong? Thanks a lot.
--Eric
URL:
http://lists.osgeo.org/pipermail/mapguide-users/attachments/20070612/7e67287
a/attachment-0001.html
