[mapguide-users] Error when do ./configure --enable-optimized
larry white
larz at neomatix.ca
Mon Jun 18 10:56:54 EDT 2007
Mark,
oh, ok.
personally, i wouldn't recommend that because i've tried the renaming
approach in the past and ran into problems
btw, you can use configure options to set the fdo locations - use
'./configure --help' to view the proper syntax.
if mapguide is looking for a specific library set, then it seems best to
use that particular set - unless you have a specific reason not
to - rather than renaming an older version.
i'd suggest using the exact version of the libraries that mapguide is
looking for. otherwise, you may run into compilation and/or runtime
problems. plus, it will be lacking features available in the latest code.
is there a specific reason you want to use older libraries?
btw, what version of mapguide are you compiling?
-- larry
MarkTang wrote:
> Hi Larry,
> Thanks. I have installed the fdo3.2.0., it isn't the version fdo3.2.2. So
> the system can't find it. Now I just change the name of the FDO folder to
> fdo3.2.2. It can be compiled.
> Mark
larry white
Senior Systems Analyst
Neomatix Corporation
email: larz at neomatix.ca
url: www.neomatix.ca
