[mapguide-users] Error when do ./configure --enable-optimized
MarkTang mark.tang at thespothk.com
Sun Jun 17 11:02:38 EDT 2007
Hi Larry,
Thanks. I have installed the fdo3.2.0., it isn't the version fdo3.2.2. So
the system can't find it. Now I just change the name of the FDO folder to
fdo3.2.2. It can be compiled.
Mark
larry white-2 wrote:
> Mark,
> based on what you've described, i'm guessing that you don't have the fdo
> libraries installed (please correct me if i'm wrong and ignore the rest
> of this message)
> these libraries must be in place prior to compiling mapguide.
> have you 1) downloaded, compiled and installed fdo and the fdo providers?
> or 2) downloaded and installed the fdo binaries?
> if not, then you need to do one of these two options before
> configuring/compiling mapguide.
> fdo downloads are available at:
> http://fdo.osgeo.org/downloads.html
> if you're compiling mapguide 1.2 rc1 and want to compile fdo, then
> download the tarball named fdo-3.2.2.rc1.tar.gz and the tarballs for the
> providers you require.
> if you're using redhat enterprise linux 4, there are binaries available:
> http://download.osgeo.org/fdo/3.2.2-rc1/fdosdk-3.2.2_rhel4_rc1.tar.gz
> -- larry
> MarkTang wrote:
>> configure: error: the default FDO include path
>> /usr/local/fdo-3.2.2/include
>> is not a valid directory. Please use the custom option
>> Where is the fdo-3.2.2 proper directory? Thanks and How to fix it?
>> Thanks
> larry white
> Senior Systems Analyst
> Neomatix Corporation
> email: larz at neomatix.ca
> url: www.neomatix.ca
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
View this message in context: http://www.nabble.com/Error-when-do-.-configure---enable-optimized-tf3933089s16610.html#a11163926
