[mapguide-users] Bad labels
Jason Birch
Jason.Birch at nanaimo.ca
Mon Jun 18 16:17:28 EDT 2007
Hi Jon,
Could you please file a bug for this on our Trac instance following the
instructions here?
<http://trac.osgeo.org/mapguide/wiki/SubmitTicket>
Please attach the images and the steps to reproduce. It would be
helpful to know what your data source is, and the column definition for
the source of the labels. And any other information, like whether you
are labelling a joined attribute.
Thanks,
Jason
-----Original Message-----
Subject: Re: [mapguide-users] Bad labels
This same behavior exists in RC2. This problem did not exist in 1.1.0
Jon Rizzo wrote:
> I noticed that in 1.2 RC1, labels are occasionally not displayed
properly.
> I have posted two images - they are the same label displayed at
> different scales. I have attached two images. bad.jpg shows the
> incorrect labels and good.jpg shows the correct labels. I'm not sure
> where those numbers came from, but the feature does not have any
> attributes with values like that. There is not a corresponding scale
> range in the layer definition, so the two layers should be identical.
This did not happen in 1.1.
> bad:
> http://www.nabble.com/file/p11102528/bad.jpg
> good:
> http://www.nabble.com/file/p11102528/good.jpg
