[mapguide-users] RE: Bad labels
Jon Rizzo
jrizzo at Langan.com
Mon Jun 18 17:06:37 EDT 2007
Done. I was wondering where that was... ;-)
JasonBirch wrote:
> Hi Jon,
> Could you please file a bug for this on our Trac instance following the
> instructions here?
> <http://trac.osgeo.org/mapguide/wiki/SubmitTicket>
> Please attach the images and the steps to reproduce. It would be
> helpful to know what your data source is, and the column definition for
> the source of the labels. And any other information, like whether you
> are labelling a joined attribute.
> Thanks,
> Jason
> -----Original Message-----
> From: Jon Rizzo
> Subject: Re: [mapguide-users] Bad labels
> This same behavior exists in RC2. This problem did not exist in 1.1.0
> Jon Rizzo wrote:
>> I noticed that in 1.2 RC1, labels are occasionally not displayed
> properly.
>> I have posted two images - they are the same label displayed at
>> different scales. I have attached two images. bad.jpg shows the
>> incorrect labels and good.jpg shows the correct labels. I'm not sure
>> where those numbers came from, but the feature does not have any
>> attributes with values like that. There is not a corresponding scale
>> range in the layer definition, so the two layers should be identical.
> This did not happen in 1.1.
>> bad:
>> http://www.nabble.com/file/p11102528/bad.jpg
>> good:
>> http://www.nabble.com/file/p11102528/good.jpg
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
View this message in context: http://www.nabble.com/Bad-labels-tf3915608s16610.html#a11184071
